Question about Rowenta Professional DM890 Iron with Auto Shut-off
Rowenta Iron DM890. Won't turn on no matter what position you put the iron in.
SOURCE: Rowenta Iron
These are called tamper proof screws and you have to get them from the manufacturer. You have to be an authorized service center to get them. There were too many law suits aganinst the companies so they placed these special screws on the units so the do-it-yourselfers can not open them. I think they just do not want the units repaired and this is their excuse. They would rather have you toss the unit and buy another one. Sorry I can not be of more help.
Posted on Jan 14, 2008
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
heatman101
  • 43501 Answers
SOURCE: Rowenta iron won't heat
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: Rowenta surfline iron turned off and won't go back on.
heatman101
Install new sole plate rowenta DMV 890
see the video and use the common sense and fix it. God bless you
Oct 15, 2012 | Rowenta Professional DM890 Iron with Auto...
Rowenta iron will heat up and then shut down. Have to keep plugging and unplugging the iron.
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
Mar 12, 2010 | Rowenta Professional DM890 Iron with Auto...
Must hold cord just so or iron will not heat up. Rowenta Professioal DM890, 1 year old.
There should be contact information with the instruction booklet so you can contact Rowenta for repairs.
Mar 02, 2010 | Rowenta Professional DM890 Iron with Auto...
I purchase the Professional Rowanta iron. The
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 05, 2009 | Rowenta Professional DM890 Iron with Auto...
DX6900 leaks when iron is on
it needs cleaning to get rid of the gunge caused by hard water
Sep 15, 2009 | Rowenta Professional DM890 Iron with Auto...
My Rowenta iron seems to be scortching my white clothes, the plate is stainless steel but seems to look iridescent
if its a light brown appering on the whites, its just to hot, lower setting. also make sure the plate is clean. the stainless changes colour from heat after a while, this is normal
Aug 08, 2009 | Rowenta Professional DM890 Iron with Auto...
My Rowenta iron will not heat up. The yellow light just continues to blink- so I know that there is some electrical current. I have a friend with the same issue with the same iron. Is there a trick to this...
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Mar 01, 2009 | Rowenta Professional DM890 Iron with Auto...
My Rowenta Professional will not come on.
Yes, there is a broken wire inside of the cord. This is a potentially dangerous situation for you as it could result in a deadly shock or a fire. The cord can be replaced for about $25.00 at a repair shop. Therefore, it may be more logical to trash this iron and get a new one.
Either way, good luck.
Feb 04, 2009 | Rowenta Professional DM890 Iron with Auto...
What is the temperature of the synthetic setting?
I would use some scraps of fabric and transfers to do some trial and error experimenting.
Keep in mind that the iron will not produce steam until the internal temperature is 212 degrees farenheit.
good luck with this.
Jan 06, 2009 | Rowenta Professional DM890 Iron with Auto...
take it down and stretch the spring or replace the spring ,it is dead ,if you cannot do it your self contact a tech.good luck
May 02, 2007 | Rowenta Professional DM890 Iron with Auto...
Rowenta Professional DM890 Iron with Auto Shut-off Logo
200 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
