Question about Leviton 5634 Dual 1 Pole Switch Decora Combo Device
Hi...do I run the exposed copper wire between the two poles on the left hand side of the switch....e.g. the middle screw and the bottom screw.? Thanks
  • 56 Answers
No there are two screws that are tied together on the right side that is the side the hot wire ties to. The other side that has two screws one at the top and one at the bottom. This is the screws that the wires from the lights will go to
Posted on Sep 30, 2010
Wiring a leviton 5641 so fan & light turn on separate with red & black wires
the 5641 is a dual switch for three way and single pole. If you want the switches to operate the CF. Connect the power to one of the two screws on the right side as you face the switch. then connect one wire to the screw on the bottom left side. connect the other screw to one of the two screws on the top left. This assumes the Red and Black you mentioned are the switch legs going to the CF.
Feb 14, 2015 | Leviton Electrical Supplies
Chainsaw not developing a spark
Remove the left side cover after trying a fresh spark plug (gapped at 0.020") with no results. This will expose the flywheel and ignition module. Remove the stop switch wire from the module body and retry for spark. If you get spark, check the switch wire and the switch itself for grounding. If still nothing replace the ignition module using a thin business card for a gap gauge. Turn the flywheel magnets under the module poles, insert the card into the pole gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the gaps don't close further. Hope this helps!
Dec 30, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I got a cooper co/alr light switch to replace one that I suspect has died. The old on had the poles on either side of the switch, this one has the poles on the same side. The white wire was on the left...
If the old switch only had two terminals/screws, then it shouldn't matter. If the screws on the new switch have color, then: silver screw, white wire.
gold screw, black wire.
If the old switch had more than two terminals/screws, be careful when turning on the first time!
Gary
Dec 27, 2010 | Cooper Lighting Lighted Switch
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
5200 no spark
Remove the left side cover to expose the flywheel and ignition module. Set the module pole gap by turning the flywheel magnets under the module, insert a thin business card into the pole gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps do not close up at any point. Remove the ignition switch wire from the coil connection (not the pole ground), and install a fresh spark plug gapped at 0.020". Try again for spark. If nothing, replace the module. Hope this helps!
Nov 25, 2010 | Poulan Garden
I have a two single pole switch. when hooking it up with line voltage on the left side of switch and neutrals tied together and ground connected i still get 120 volts to bottom of switch when i flip the...
Just to make sure: Your white wires should NOT be attached to the switch in any way. If you have multiple lines coming into the box, both incoming and outgoing, strip about a 1/4" of insulation off all of the white wires, wire nut them all together and tuck them into the back of the box. Do the same with the ground wires and add a piece of wire to run to the switch if it has a ground (green) screw.
On a double switch the two screws on one side that are close together have a jumper on them so you only need one black wire from the circuit breaker to power the switch. If you need seperate circuits for the switched objects you can cut the jumper and run seperate wires to the top and bottom switches. The two screws on the opposite side are further apart are for the black wires that come from the switched objects.
Aug 31, 2010 | Cooper Wiring Devices "ACE" COMBINATION...
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
One leg of the 240 line is erratic
At the breaker box, you have 2 poles into a 240 volt, any amp breaker, one side is 110/120/ of course, and so is the other side, so if the erratic side is erratic up and down the panel, maybe the screw has come loose for the service entry wire from the meter. If not, then if it is on the other side, the load side of the breaker, then the breaker is bad, or that screw is loose, these are hot too! Got it? Try it again, Look at the panel, top left, top right, 2 big wires in, one is 120v, the other is 120 v, one side feeds the left bank, one side feeds the right bank, they both cross in the middle, every breaker so they don't try to get 240 v from the same side, So each big 2 pole breaker gets it's power from both sides.Now, one of yours is erratic, check it at the bottom of the breakers where you can see the exposed metal, don't touch it with anything but a tester or you will get zapped big time. If you are afraid of electricity, get an electrician to do it. Be very carefull in there, everything is hot, even when the main is switched, the top lugs are still very hot!! In order to tighten the bolts on the big wires, if they are loose, you have to pull the meter, the power Co. will do it for you without the building dept, hopefully. I hope this helps.
Feb 11, 2010 | Electronics - Others
I am replacing a single pole switch that contains two rockers - one controls some lights, the other the garbage disposal. I am using a Levitron 5634; when I removed the broken switch it had 3 wires...
You have the hot wire on the wrong side of the switch. The side of the switch with the fin is where you put the hot wire. On the other side of the switch where there is no fin is where you put the other two wires one on each screw. When you have it wired that wat your switch will work like the old one. Also if you would like the lights to come on with the top part of switch. But works with the bottom switch you just need to switch the two wires from top to bottom.
Jan 20, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
Leviton 5634 Dual 1 Pole Switch Decora Combo Device Logo
49 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
