Question about VeriFone PINPad 1000SE Network Terminal
Hi my pinpad say err-no mkey I did turn the power off and take both side of the wire out and waited 1 min and still dose the same help me plz
2 Suggested Answers
  • 113 Answers
SOURCE: getting mkey error on pinpad 1000
IT MEAN I THINK THAT YOU LOOSE THE DEPLOYMENT KEY INJECTKEY INJECT&APPL LOAD NEED TO BE INJECT AGAIN
Posted on Dec 01, 2011
C-3b04 err
Turn off the main power sw inside machine not the one on side of control panel. Hold down utility/counter and turn on main power close front door wait for trouble reset. touch trouble reset. wait for OK then power machine off wait ten seconds power machine on again should come up to ready to copy. IF code comes back do not reset again machine is telling you it need help have it looked at by a technician.
Jul 12, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Pinpad is blank
the pin pad will be blank if not in use, if in use and is blank check the conenctions if still blank needs replaced.
unplug power from terminal , disconnect pinpad, reconnect pin pad wait 1 min before turning on power, it will do a pinpad test, see if fails this test if it does call for replacement
Apr 06, 2014 | VeriFone VX510
Getting mkey error on pinpad 1000
Dec 01, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
I have a Westinghouse RV525V-R*4 Virtuoso Fridge (Electronic Display) which beeped twice and gave an error today on the display - Cnn Err. The dispay was showing the temp in degrees F. Tried everything...
I wasn't keen on the 48hr period so I tried a work around. I disconnected the front display which reset the alarm in question. To disconnect the display you have to disconnect the wires that supply this power. This is located underneath the top plastic hinge cover for the freezer. Remove the cover
May 31, 2011 | Westinghouse Refrigerators
Can you turn off one of the left or right sides on a La Cimbali m29 Espresso machine?
1-Cover the buttons on offending side (paper and 1 min to do)
2-Reprogram one side to give it a short dose. (5 mins to do)
3-remove power to group valve (screwdriver and 20 mins to do)
Note if you do remove the power, please leave a note for the crew as they will probably call a technician in to 'repair' it again.
Aug 19, 2009 | Espresso RMI La Cimbali Espresso Machine
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
May 25, 2009 | Canon Cameras
ERR 99
try cleaning the battery contacts and the contact spring tabs in the battery compartment... also visually check to make sure the tabs are sticking out to make good contact with the battery terminals.
Also here's an excerpt from a canon blog ..it's a quote from a Canon usa service guy...
hope it's a help for you..
One of our participants in the long comment thread below (Tom) got this in a message from Canon USA. It may help some of you isolate the problem before you post a comment/question.
To isolate the cause of the issue, we suggest that you do the following:
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
May 25, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Tv stopped working
Hi. This tv may have an issue within its contents.This issue concerns the power supply board. to confirm this, unplug the tv from the surge protector, if any, and wait for 3 Min's. after this 3 min wait, plug this unit into a wall outlet and power up. if it dose not power up, you will defiantly have to replace the power supply board.
Please rate and god bless:)
Apr 02, 2009 | iLO IWT3206 TV
Just stop working
try restoring the router to factory defaults. you can do this by
unpluging the router.  Push and HOLD the reset button,
DO not release the button,  plug the power of the router.  wait for 30seconds. release the reset button.
wait for 1 min, turn off router,  and then turn on try to reconfigure your router by using the setup wizard
Jan 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
VeriFone PINPad 1000SE Network Terminal Logo
283 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
