Question about Element Electronics FLX3711B 37 in. LCD TV
Element 32" TV does not turn on. Red/blue on indicator light is flashing red
  • Element Elec... Master
  • 19,396 Answers
Hi.
If the TV stays in standby and does not wake up, then the TV has on protect mode after detecting a fault.
When this happens higher voltages from PSU get shut down to prevent further damage
Try disconnecting power cord for about ten minutes, restart the Tv with no cables attached.
If that does not work, then there is an internal problem, PSU, main board and inverter must be tested.Here a description of general procedure:
Testing LCD TV.
Unless you are a technician, if disconnecting power does not fix the problem, better calling support.
The best way to contact an authorized technician is by ringing the number listed on the owners manual.
Parts Here:
ShopJimmy flx3711b
Posted on Sep 05, 2010
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
When i turn on my LG 32lg30 on, the power indicator light flashes red 4-5 times, then the monitor turns on to a steady dark blue color. I tried to press buttons on the remote but there is no display.
Now there is a challange.
My LG has not shown this behaviour yet. Do you still have the DVD disk that came with the TV.
If you do you will get your answer there I presume.
Make sure that you are using the correct input.
kollagunn
Feb 21, 2012 | LG 32LG30 32 in. LCD HDTV
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Any ideas on what to do for an element tv that won't turn back on..the red/blue light is not on either. It was working fine and when I shut it off the red/blue light went out also now I can't get it back...
Tries tv unplug,replug it back like about an hour.By letting the tv resetting itself back to the tv factory setting.Now,the tv should be working again.If it still have the same result.Mean the tv power supply board,that the board where the power a/c plug into it.The causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 24, 2011 | Element Electronics FLX-3211B 32 in. LCD...
My 32" Element LCD tv is broken. One night I was watching tv and all teh sudden there was blue, red and yellow lines running horizontally across teh screen, audio was fine. I turned it off and unplugged...
Yes!
It has suffered a breakdown in the power supply and the damage has also spread as far as the sustain boards that control video and convergence. This is not a DIY and the repair for parts is $300 + labour. However, get a few quotes. At least a 32 in is a little more transportable than a 6' model
Please rate my help++++Thanks for using FIXYA
Jun 28, 2010 | Element ELC-HS321 32 in. LCD TV
Red light flashing...no picture. TV not turning
Probably a failed main power supply. There are at least two supplies; one that keeps the remote function alive continuously and the second that is turned on when the set is ordered to operate. The smaller supply is a low voltage circuit and that is providing your error indication.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Element Electronics FLX3711B 37 in. LCD TV Logo
782 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
