Question about Samsung Televison & Video
Dear sir i have a samsung t.v model no.cz-21k30ml,when tv start after some time picture go,sound normal ,then we do tv standby mode &restart picture comeout.we are changed it s ic tda 9381ps/n3/3/1959 but now problem as it is. ple............tell us it s solution.
SOURCE: Sony KV 32HS500
Sony KV 32HS500
Posted on Feb 25, 2008
SOURCE: Westinghouse LVM-37w1 Goes immediately into standby mode
Power suplly. In my case I should have done research on a lot of things before purchase - westinghouse doe snot acknowled any power supplly uissue but they would say that, and this is a direct quote from them, "Westinghouse's failure rate is less than 2%, which is great by industry standards. Unfortunately, when you sell millions of televisions, 2% is still a lot of televisions. There have been no recalls on this model (or any of our models), but it's not surprising to find a similiar issue on more than one of millions of televisions."
In other words they calim there is nothing that is really their fault. However the first thing the repair guy said before he even looked at it was "Power supply". He opened it up and tested - power suplly. However to complicate matters more I made is huge mistake of buying into a scam offered by eCost via Service.net . A two year, 100%, in home service, warranty. Bottom line is since June 8 my Monitors has not worked and sine July 7 it has been sitting untouched, not here, but at a rprair facily over 50 miles away. As of yesterday August 7, I was told Westinghouse no longer makes or provides power supplies for this unit. On top of that the repair facility will not return it to me unless i pick it up why? Because it can't be fixed and because service.net will not pay them to return it to me.
So solution at thi point for anyone with power supply issues is to try and repiar it yourself. And then in the future never purchase anything from westinghouse again. (And if offered any sort of 100% all cost covere din home warrabnty from service.net run away screaming)
Posted on Aug 08, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
  • 56 Answers
SOURCE: my samsung TV can't display
check feedback path from collector of h output tr, check voltages at pin 5 of tda 6107 it shuld vary wrt screen voltage
Posted on Jul 19, 2009
bhatgiri73
  • 106 Answers
SOURCE: hi samsung tv using TDA
180 volts from LOT o/p to drive pict-tube guns is missing . or vedio driver ic is faulty.
Posted on Jan 22, 2010
I have a samsung tx-t2782 with red green and blue pinstripe running horizontal across top of screen. not a ground loop and theres no magnetic interference.
hello spins,
If your problem just pinstripe on top of screen , but picture ok (normal in picture), try it to enter the factory mode. In standby position press info-menu-mute-power. Enter to deflection adjustment- choose - vamp (VA) or v shift (VS). Change value data by pressing + (or right cursor) and - (or left cursor) to shift or increasse amp. If it work, your tv will normal.
But its nor working, you should call samsung technician.
Good luck.
Mar 30, 2011 | Samsung SlimFit TX-T2782 HDTV
Samsung TV could not turn on. no sound/no picture
Hi my name is Roety,
I can help you with your issue ,
You need to replace your lamp.
remove the lamp and check the number on it, then search for it on google.
the lamp door is in the rear
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Oct 10, 2009 | Televison & Video
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Standby mode intermittently.
Hello, FixYa
I have normal tv model CNT 2588 code 981, remote control was out of order and I tried to buy a new one from many places in UAE, Suadi Arabia & Egypt but I failed due to it is old model and no spare parts. So I use the tv function through Satel Decoder and use tv main power button for swithing on and off. It seems that caused a problem and tv now could not get power to switch on. Would you e-mail me with the repair manual including the Elect.Circuit to try to repair the problem. Also if you can arrange to send me a new remote control model CNT 2588 code 980. Since the TV Picture and sound are still in an excellant condition, please e-mail me you kind response with the cost if any to send you my Address and money.
Thanks in advanced.
Mohamed Said
Oct 30, 2008 | Televison & Video
Model RE44SZ21D when I switch TV on it maks a whinning sound like a hard drive not reading properly and switches back into standby. Sometimes it will start, (normally if not tried for sometime) stays on...
hello john.
this is a late suggestion,but if you still have the set & the proplem
in existence.
then i suggest you check with the lamp---situated on the right hand
side ,two screws to undo--once in further two screws--pull back the
casing clean with a dry cotton cloth & with that clean the cooling
fan just adjasent to the case.+ remember to leave the tv on standby mode for 3 minutes before you completely switch it off ,as this helps to cool down the lamp the fan at rear still propels while the tv is in standby mode.--------ASH
Aug 14, 2008 | Televison & Video
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
