My panosonic ct32hxc tv went dead with no power. I changed the 6.3 amp /125 volt fuse and it came right on, but with no sound. I opened the back and do not detect anything loose or disconnected. Is there and audio fuse as well? Thanks
  • 666 Answers
Yes there is in fact a fuse for the audios as well if your not getting sound this is normally the first thing to check what you will want to do is find an exploded view or schematic or simply diy guide via google or if available the users manual that came with the product
hope this helps
Robb
Posted on Sep 05, 2010
Teac AG-V7700 keeps bowing fuses
I hate to say it but it sounds like one of the audio chips that drives the speakers shorted out! The high powered outputs (more than 7 watts) need both speaker wires to be ungrounded. You will need to find someone to replace the defective chip or else get a new unit.
Nov 25, 2013 | Teac Audio Players & Recorders
Big Screen RCA Tv Model #P60923BL or OM60923BL
bamones, it`s possible but not likely, remove AC cord from wall outlet, remove back from set and follow the AC cord where it goes into the set, fuse is right beside where the AC cord attatches to the board, if the glass is black you have a dead short in the power supply, if it`s open but not black then try replacing the fuse, amperage is marked on the silver metal end of the fuse, look for a number followed by the letter "A". Example;
5A 125V would be a five amp fuse rated at 125 volts, DO NOT replace with any other value, good luck, BMW Rider
Dec 19, 2007 | Televison & Video
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
How to change the fuse on a panasonic CT-32SL13G What kind of fuse is it and where is it located
Apr 04, 2009 | Panasonic CT-32SL13 32" TV
125 v 4 amp fuse keeps blowing
if you plugged a 125 volt tv in to a 220 volt outlet you more than likely fried alof of the componets in the tv. Putting a bigger fuse in there is only going to increase the risk of it catching on fire so i would not recomend that. you might replace the power supply and cross your fingers and hope that nothing else cooked when the 220 volts hit it
Mar 14, 2009 | Televison & Video
Panosonic nn-t790 microwave
I pulled the top and sides (one piece) of the microwave. Near where the 110 volt line goes into the unit is a standard fuse ( 18 amp). I used an ohmeter on ther fuse and determined that it was not working and replaced it. Problem solved - unless it blows again.
Nov 06, 2008 | Microwave Ovens
Pioneer rear projection tv
You might want to check the power supply/deflection board for bad solder connections. i found on the one i was working on. the standby and main power relays was broken loose from the board also check for any other solder joints that look cold jointed. i have been a tv technician for 13 years.
I hope that will fix your problems...
Keith Mitchell...
May 07, 2008 | Pioneer SD-P62A3-K 62" Rear Projection...
Panasonic tv CT32SL14J
You'd better make sure that there's no power on in the TV by checking the red light in front of it. If it's sure there's no power when the TV's plugging in the outlet, then the problem may be the fuse.
The GLASS fuse locates right after the power cord where is connected to the TV. Using a screw driver to open the back (make sure the power cord already taken out from the outlet !), try to have the power cord side opened as wide as you can. You can use your finger tip to push straight from bottom to up to take the fuse out. For sure, you can see the fuse having the core disconnected in the middle.
To my case, the fuse was 6.3 Amp and 125 Volt, but I can only get the 6.3 Amp- 250 Volt at my local Radio Shack store. However, it's fine to replace with this higher volt fuse.
It costs about 4 bucks for a bag of 4 glass fuses. Worth to try with the "practice" and for having your TV back on again !
~NDo~
Feb 24, 2008 | Panasonic CT-32SL14 32" TV
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
