Question about Sony CDX-RA700 CD Player
RADIO WIRING DIAGRAM FOR 1988 TOYOTA PICKUP
I HAVEA NEW STEREO BECAUSE THE OLD ONE WAS STOLEN AND THE WIRES CUT OFF. i NEED TO KNOW WHAT COLORS TO MATCH UP TO MY STEREO, 1988 TOYOTA PICKUP.
  • Anonymous Nov 13, 2008
    which wires are which
5 Suggested Answers
mixmaster
  • 626 Answers
SOURCE: radio wiring diagram
THis site has most other Mitsubishi Vehicles.
I have not seen yours listed on there, but generally the wring diagrams are the same across the models.
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Mitsubishi.html
Best of Luck.
Posted on Nov 04, 2007
  • 323 Answers
SOURCE: SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Posted on Apr 21, 2008
SOURCE: WIRING DIAGRAM FOR 1988 TOYOTA PICKUP CAR STEREO
just use a volt meter and test around to find your powers and grounds. then look behind the speakers to find the wire colors and compare to behind the stereo
Posted on May 26, 2008
  • 19 Answers
SOURCE: I need a wiring diagram for a sony CDX-RA700 car
look on the wires... the letters are small but they should tell you...
Red is hot
Black Ground
Yellow constant
orange should be for antenna
blue is for remote
I can't remember the speaker breakdown... but again, look carefully, and you should see it.
Posted on Apr 10, 2009
  • 3 Answers
SOURCE: I need the radio wiring schematic for a 1988 toyota 1 ton pickup
http://www.modifiedlife.com/1986-toyota-pickup-car-radio-wire-color-codes/
Posted on May 04, 2009
Need stereo color wiring diagram for 1995 Chevy Astro Van. Old radio stolen.
Easiest to replace would be the factory Delco AM/FM CD...plug in to existing terminals. If wires cut, you should include the plug in terminals with the replacement radio...Local Pic-A-Part is my go to salvage yard radio $25-$75...Walmart also sells radio wire install kits...$14.95? Hope this helps.
Apr 21, 2016 | 1995 Chevrolet Astro
Car audio wiring color codes.for 1988 ford f150 truck
Thanks for using FixYa.
1988 Ford F150 Truck Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Jan 25, 2011 | Car Audio & Video
Radio installation
1985 Chevrolet S10 Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 4′ x 10′
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 08, 2009 | 1988 Chevrolet S-10
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
I need the color codes for the radio wires!!!
PLEASE RATE THIS INFORMATION.
1993 Jeep Cherokee Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Mar 25, 2009 | 1993 Jeep Cherokee Country
Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
Mar 19, 2009 | 1986 Honda Civic
Need to get wiring diagrams
1988 Dodge Ram Charger Car Audio Wire Color Codes
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange
Car Audio Front Speakers Size: 6′ x 9′
Left Front Speaker Positive Wire (+): Green
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
pls rate
Jun 23, 2008 | 1988 Dodge D-Series Pickups
May 12, 2008 | Car Audio & Video
Sony CDX-RA700 CD Player Logo
430 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
