Question about Garmin nuvi 650 GPS Receiver
Touch screen not responding at all. Garmin powers up okay.
This is Garmin's response to me after having the same problem on a 2 year old Nuvi 650: We are no longer replacing or repairing this model unit. However, let me give you some steps to try to calibrate the screen of your unit. The following 'Fix' did not work. I won't be buying another Garmin.
To recalibrate the touchscreen on your nuvi 600 series device please follow the steps below:
  1. Plug the device into the computer via USB data cable
  2. Double click My Computer (Mac Users can skip this step)
  3. Double Click the Garmin or nuvi drive
  4. Double click the Garmin folder
  5. Delete the GUPDATE.GCD file (if this file is not on the device please skip to the next step)
  6. Unplug the GPS device from the computer
  7. Power the device off
  8. Press and hold the Power button
  9. After a short period a screen should appear that says Touch Dot
  10. Release the Power button
  11. Touch the dots as they move around the screen.
Your touchscreen should now be recalibrated.
If the screen is still not responding, then the unit will need to be replaced with a new unit at this time.
With Best Regards,
Benjamin B
Product Support Specialist
Automotive Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Benjamin B, Associate #6891
www.garmin.com
Additional solutions may be found at http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Posted on Dec 30, 2010
Garmin 265W After cleaning the screen with a duster--switched on, the screen will not respond to touch, I have updated software but cant use garmin as screen wont respond. cant hard reset again as screen...
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Aug 28, 2011 | Garmin Nuvi 265W GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen on my garmin nuvi 205 stopped responding
If the touch screen is not working properly, calibrate the touch screen.
Turn Nuvi off and then back on.
Slide power key to the right (lock). Hold your finger on the screen for about 30 seconds until the calibration screen appears.
Follow the directions on screen instructions
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
My garmin (nuvi 670) touchscreen does not respond to any touch
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Apr 08, 2010 | Garmin 010-00358-00 GPS Receiver
Garmin Nuvi 255 2008 screen not respnond to touch
There should be a reset on it and it should bring it back.
Dec 25, 2009 | Garmin Nuvi 255 GPS Receiver
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
Garmin c330
Try to calibrate the touch screen. Push and hold the power button on until you see a white dot on the screen. This is the calibration mode. Touch the dot and another dot will apppear, now touch this dot again, keep doing this until the unit reboot.
If you touch the 1st dot and nothing happens then the digitizer on the LCD is dead. If the unit is still under warranty, get a RMA and return it to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 650 GPS Receiver Logo
370 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
