Question about Bissell 1672 BIGgreen Wet/Dry Vacuum
Need to take apart a Bissell Big Green Cleaning machine to replace pump
SOURCE: Bissell Big Green Machine Model 1672 will not pump cleaning liquid
have a Bissell Big Green 1672, the older canister model. Went crazy trying to figure out how to get to the pump. Finally figured it out. The top green "shell" covers the motor & pump and is separate from the "grey" plastic housing. Using a screw driver, insert it between the small gap between the top "shell" and the housing. If you look at it with it laying down on the top, you will see the small 1/4" gap. Gently pry in between the two and work your way around. It will start to lift up and then you can easily work your way around and it will pop off exposing the motor and pump. Note that the wires to the on/off & pump switches will sill be attached to the top shell. If you take them off note where they came from and make sure they are all on when you put the top back on. I have had my Green Machine for years, what a work horse! To bad they don't make them anymore, the new ones that replaced them just don't have the same durability and power as the older Green Machines.
Posted on Mar 11, 2009
SOURCE: I need instructions for the Bissell Big Green powerbrush
I recently did a Google search an owners manual for my inlaw's Bissell. I just googled your 168-3 and found a manual, hope it is the right one,
Posted on Apr 09, 2009
  • 11 Answers
SOURCE: I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (
The motor for the pump rusts because the design of the pump does not seal well against water leakage. Water gets out (the only thing that seals it is silicone grease) and rusts the motor. It can get so that the front of the motor shaft wobbles and that makes the leak worse.
As noted, a new pump/motor assembly is cheap. If you get one and replace it, don't forget to tie-wrap the hoses, as the factory does, or you will get leakage at the hoses.
Posted on Sep 19, 2009
SOURCE: I own a old Bissell Big Green Cleaning Machine and
I just saw one on USAVacuum.com It's about $29
Posted on Mar 13, 2010
SOURCE: I need a Bissell Proheat 8910 Schematic drawing
Here's a parts diagram http://www.nelsonappliance.com/bissell+proheat+parts.asp
Posted on Jun 03, 2010
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    How do I clean my Bissell carpet cleaner model 47B2
    Hi Susan. Cleaning the machine is easy. You'll need to remove, empty the dirt container, rinse thoroughly. Also, remove and rinse the foam filter.
    Please refer to page 7 in the User's Guide for a complete list of cleaning tips.
    Here's a quick link to download the User's Guide: http://www.bissell.com/user-guides/?cid=ccsocial
    Aug 18, 2013 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Bissell big green clean machine extention hose not spraying
    Hey, sorry you're having difficulty with the spray on the hose.
    Here's a quick link to troubleshooting steps to assist you:
    http://www.bissell.com/FAQDetail.aspx?id=23646&cid=ccsocial
    Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
    Little green machine will not spray. Can I fix it?
    yes according to the model you have look up a schematic on line and take it apart you will see the pump assy the pump # is 6035029 this can be purchased on line i got mine at VacParts Warehouse.com think it was about 14 or 15$
    Sep 11, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Big Green Machine
    Go to Bissell.com and see if a user manual is available for download. You will need your model number tho.
    Jan 09, 2008 | Vacuums
    Dec 19, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
    Bissell 1672 BIGgreen Wet/Dry Vacuum Logo
    1,049 people viewed this question
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
