Question about Magellan Triton 400 Handheld GPS Receiver
I tunr the power on and it freezes up on the main screen
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 154 Answers
The unit has corrupted software in the internal system. If the unit is in warranty .. return it to Magellan
Posted on Dec 01, 2010
Black screen and suddenly grey no control on tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 12, 2016 | Sony BRAVIA KDL-46XBR8 46 in. LCD TV
Once I power up the unit it freezes to the opening screen with Garmin in the middle. Have tunred on and off several times and it freezes every time
I have had a similar problem with a Tomtom - at some stage the maps became corrupted.
The solution with the Tomtom was to plug it in to the computer via usb cable and re-load the maps. I believe Garmin have similar computer software available, but you may be able to find more information and relevant updates on the Garmin page for your item:
https://buy.garmin.com/shop/shop.do?pID=8109&ra=true#gpsmap545
hope this helps.
Mar 14, 2011 | Garmin GPSMAP 545s GPS Receiver
Few minute ago when i tried tunring on my pc it just stayed at the abit-intel loading screen thingy. (im entirely new too pcs fixing them that is ) it too about an hour or so befor it would tunr on normaly...
It could be the hard drive or any usb devices plugged in when booting up the computer. Try unplugging the hard drive and remove any USB devices and then try turning on the PC.
Dec 06, 2017 | Abit AB9 Pro Motherboard
Freezes on android splash screen
It may mean that your Android need to be re-flashed with the update that you have on your SD card. While your phone is off hold the HOME and THE POWER button at the same time to enter recovery mode. Once you see a triangle with a memory chip under it open your keyboard up and press ALT+L, once here you will see options to wipe phone ALT+W and then ALT-S to re-flash the phone again. This should bring your phone back for you so it will boot up, the only thing is that it will lose what you had on the phone as apps, but those are easily download-able again.
Jun 05, 2009 | Google Android
Our Samsung 32" flat screen will not turn on
Need to get service for main board replacing.
Feb 12, 2009 | Samsung LN32A330 32 in. LCD TV
Screen freezes
I did use the Premium live chat with you. I went through all the steps again that I already did on my own - i.e. resetting the pin hole with power on and power off...touching the screen in the corner when it was powering on....nothing changed.
I called Magellan. My warranty is still in effect and the Magellan rep gave me a repair number and address to send the unit. I will have it back and working in 7 to 10 days at no cost to me.
I wish it had been a really quick fix, I use my GPS in my business. I'm thankful for the warranty. I wish I knew why it did this so I can avoid any possible repeat of the malfunction.
Regards,
Judy in Arizona
Aug 23, 2008 | GPS
Camera problem
that is shake/blur warning and you need to use better batteries if you use cheap batteries I find that the camera will use them really quickly try Energizer Litium for digital cameras you will get about 600 shots out of them
Jan 21, 2008 | Nikon COOLPIX L10 Digital Camera
Power not turning on
Power supply failure! Requires several steps==
1)Pull main board & power supply board
2)Check horiz output xistor = shorted? Replace w/ first quality
3)Carefully solder horiz drive circuitry from HDT to base of o/p
4)On power board--replace shorted converter transistors 2SC4834 and R607 .1 ohm 1/2 watt fusible
5)reassemble.     Let me know how it goes.....T.
Oct 22, 2007 | Sony KV-36FS16 36" TV
Magellan Triton 400 Handheld GPS Receiver Logo
46 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
