Question about Olympus SP800UZ Digital Camera
What kind of HDMI cable I need to UZ800 - Olympus SP800UZ Digital Camera
  • 359 Answers
The Olympus SP-800UZ does have a Type-D, micro HDMI port.
So, you need a HDMI cable with on one end a micro HDMI connector and on the other end a normal HDMI connector. Lie this one: http://images-en.busytrade.com/175801200/Micro-Hdmi-Cable.jpg
Posted on May 09, 2011
How do I get Netflix onto my television so that I can watch netflix
Are you using a computer to play Netflix? In that case you need to connect your computer to your TV.
This can be done with multiple kind of signal cables (depending on what kind of input your TV has, and output your PC has).
The most common way with newer TVs and PCs is using a HDMI-cable. This is also the easiest way, as it usually connects automatically when you put the cable into your computer and TV.
This is a standard HDMI-cable:25498683-nnoqddbo2llde4pwvwvp0m30-2-0.jpg
This is what a HDMI-Input looks like.
Mar 01, 2015 | Netflix
Hdmi cable cables
Have you looked at your tv for HDMI inputs? What do you want to connect to it? There are two kinds of Hi def cables, one has five rca cables ...3 for video and 2 for audio. The other is for a standard HDMI cable. Your tv should have one or both types of inputs. Converting to HDMI cables will not solve anything, because even some HDMI sources do not embed audio on the cable. Converters that do embed cost several hundreds of dollars, but you must have compliant TV's and devices you wish to connect to be sure they will work..
Jan 04, 2014 | LG DU-42LZ30 42 in. LCD HDTV
What kind of HDMI cord do I need to purchase for this TV, I am running DISH Network also. Thanks!
There is only one type of HDMI cable, so any HDMI cable should be fine. Component cables are an alternative to HDMI cables, but keep in mind that component cables do not carry audio, so you will need to have the audio connected separately. Our HD receivers work great with HDMI or component cables.
Phillip Chang
DISH Network Customer Service Representative
Feb 08, 2011 | Sanyo 42 in. LCD TV
How to get hdmi
Im not sure i understand your question, HDMI is a kind of cable that transfers video aswell as audio in very high quality between devices. For a device to be able to use an HDMI cable it needs to have HDMI ports on both devices. HDMI cables are common for connecting:
desktops/laptops -> tv
tv -> desktop/laptop
surround sound -> TV
satellite box -> TV
media player box -> TV
and of course:
TV -> TV.
HDMI cables can be found at basically every electronic store or department store that sells electronics. They can also be found fairly cheaply over the internet.
Feb 07, 2011 | Televison & Video
My picture is not cystal clear. Do I need a Hdmi cable with this tv or some kind of cable for a clear picture?
All HD televisions need HDMI cables for clear picture. If you don't have one, you're not utilizing HD. Opt-World has some good, low priced cables for HDMI.
Dec 01, 2010 | Element Electronics Televison & Video
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
What kind of cable do I need to connect Bravia 40 inch to Dell inspiron 6000.
You need an HDMI cable to connect the 2 devices. Probably, your Bravia is shipped with that cable. Just make sure that your laptop has an HDMI port built-in.
Dec 21, 2009 | Dell Inspiron 1525 Laptop
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Would a HDMI cable help a 720p TV? If so what kind?
HDMI cables are the best for HD resolutions. Any kind will work fine since they are all digital cables. They either work or they don't :) I get my HDMI cables here. They are inexpensive and quality.
Sep 06, 2008 | Televison & Video
Olympus SP800UZ Digital Camera Logo
82 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
