Question about Weather King Heating & Cooling
Dear Sir/Madam, The 30-amp, 2-Pole Contactor, White Rodgers item/part no. 90-244 recently failed in our Weather King 90-Plus air-conditioning system (in the outdoor unit). Other "identifiers" on the ID label of the removed part are: "RBM TYPE 122" and "122-901". Could you please tell me if I can purchase the replacement part from you and what it would cost? And, what would your delivery time be? Thank you for your kind service and the great performance of your Weather King system for us over the years. Sincerely, Earle Gould Wilmington, Delaware tel: 302-999-9132
  • 24 Answers
Try going to a local airconditioning supply or ask a tech for a double pole 30 amp 24 volt contactor.
Posted on Sep 05, 2010
Why is my Weather King A/C Model #10AJA4201 not cooling house? Fan blows warm air. What is problem?
check the outside unit to see if it is running. If its not check the run cap which is the big silver round object. Make sure you are getting 240 volts to the contactor;
Sep 13, 2014 | Weather King Heating & Cooling
A/c blower comes on but outside unit does not
do you have power to the outside unit. If so you may have a bad contactor or loose 24 v control wiring
Apr 23, 2014 | Ruud Rheem Weather King 24 Volt Contactor...
How do I access the contactor? Where can I get a replacement contactor?
The contactor is in the condenser outside take off the power panel box. The contactor is the a rectangle box. You can get a replacement at a local HVAC parts store.
Jul 30, 2011 | Weather King 10AJA3601AH Air Conditioner
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
I have CK49-18. I am looking for replacement double pole contactor for a do it yourselfer without a license.
Hi.
Go here to get that contactor... from what I can tell from your model number you need a 24v coil and a 30-40 amp rating on that contactor...
heatman101
Aug 30, 2010 | Goodman CKL49AR49 Air Conditioner
I removed the blower from the furnace to clean it. After installing the blower the condenser would not come on. The furnace heating works okay The air conditioner works and cools the house if I force...
You don't have the t'sat wires to the outdoor unit hooked up. They should be on the y & c terminals. If they are you may have a burnt out contactor coil. It should read 24volts at the contactor coil when you are calling for cooling
May 23, 2009 | Weather King 10AJA3001AH Air Conditioner
Contactor will not pull in
Check the cotactor coil for 24V. Leads on the side.
May 23, 2009 | Weather King 10AJA6001AH Air Conditioner
Amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Jan 31, 2009 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
83 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
