Question about GE JEM31 Microwave Oven
I have a GE microwave oven, JET342G-001. I lost the temp probe. The local shop ordered me one and it does not fit. This probe has a tiny number 2 stamped on the plastic collars. He says it was corect. Please help! What number should be stamped on the temp probe? Thank you!!!
SparkGap
  • 363 Answers
SOURCE: I recently purchased this home,
The manual is available on the GE web site
http://www.geappliances.com/service_and_support/literature/
Type in the model number
Good Luck.
Posted on Aug 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker XL1800 Microwave Model # JVM1870SF001
(I also replied via e-mail)
Sorry, but the subject lines get cut off after so many characters.
Thanks for replying.
Part # DE63-00204A looks like a valid Samsung part number but it doesn't show up anywhere, so it's likely a proprietary part made only for GE and not available separately.
You can see a helpful exploded view of this model here.
Then you can go here and enter your model number and come up with the parts list. This site has much better prices than GE.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Chances are you will end up having to but more than you want to, but not the whole door.
Posted on Sep 10, 2008
SOURCE: Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Posted on Nov 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: WHat part number for this GW Microwave oven thermostat?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It will tell you where each one is located and what it's called, and should have the part numbers.
Three of them should read normally closed and one should read open.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you still need help, let us know.
Posted on Jul 05, 2009
What will fit in the cutout for GE microwave model JE1540WW 001 Countertop Microwave
Call GE support and ask them, and be sure to give them the full model number.
800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET Saturday: 8 a.m. - 7 p.m. ET Sunday: Closed For more free DIY help, feel free to contact me via my site. Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 12, 2017 | GE Microwave Ovens
Making a grinding noise when turned on and the turntable does not rotate at all
sounds like a broken gear for the turn about.
you can remove the casing of the microwave and examine the bottom area where the gears and motor are located and see what parts need to be replaced.
the parts can be ordered at you local GE appliance repair shop. ( they might even have them in stock -- take the broken parts down to their shop with the make,model and serial numbers ).
c...
Feb 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Built in2002 g.e. profile convection/microwave oven sensor model #je1590bc 001. how can i get instruction manual off the web or hard copy
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts for GE by entering your full model number from the tag on the oven here
For other brands, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 02, 2011 | Microwave Ovens
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
Dec 11, 2010 | General Electric Microwave Oven
GE microwave model number JVM230WV 001 popped while cooking now when turned on it will only make a humming noise. Light comes on but no heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need to find and order the correct mounting p;ate and bolts for mounting the GE Spacesaver XL1800 microwave.
open door to unit get model number and got o searspartsdirect.com and enter it in to get part number and prices...... or shop locally,, also repair clinic.com also sells parts and shows pictures of most hope this helps let me know
Apr 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The interior light is out on our GE Profile Sensor Micorwave Oven. I don't see any directions on how to replace it. Can you help? The model number is JE 1860CB 001
You have to remove the outer cover to replace the bulb in this model.
The bulb is located in the air duct that covers the magnetron on the right side of the unit.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven (entered as JE1860CB01 without spaces) here.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores or you can order them ahead of time here.
Jun 21, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace burned inside ceiling of microwave?
Do Not Use The Microwave. If You Need Parts Try Finding A Part Number And Use Ge To Order Parts. Click Here To Order Parts
Jan 15, 2009 | GE JEM31 Microwave Oven
GE JEM31 Microwave Oven Logo
264 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
