Question about Refrigerators
Frigidaire RL6003B Not Cooling The element at the back of the fridge is only hot in the bottom corner, I guess this points towards the pump not working? The fridge temperature is mild at best and does not change when the control is changed inside.
  • 1 more comment
  • billing51 May 12, 2008
    Not really much knowledge it just seems to be the only reason that fits the facts... It's not covered by warranty anymore so am hoping I can find out how to get it fixed without having to pay an expensive call out charge...
    yes the pump is humming
    There is not a freezer in this model....
    Genius:
  • 3,422 Answers
I suggest you to go for a repair anyways here is some usefull info:
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Goodluck,
Please don't forget to rate the solution
Posted on May 12, 2008
  • Priya darshan May 12, 2008
    My solution no. is 2 so if you would like to rate it then please rate the sol. no.2
    President:
  • 2,712 Answers
This could be a problem with the air baffle unit, or the evaporator fan, wherein cold air from the freezer does not get directed into the fridge section. Could even be a bad door switch preventing the fan motor from running.
If you find that the freezer is not cooling as well, it could indicate a problem with the compressor.
In any case, I would recommend you contacting a professional to service this. If ot is under warranty, then best contact Frigidaire or the point of purchase.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 12, 2008
    It seems to be most likely the compressor in this case..
    Sergeant:
    Champion:
  • 427 Answers
It may have simply experienced a general hardware failure. I hade the same problem with my refrigerator, luckily I still had a warranty. When i had it fixed, I asked what happened. They said that after conciderable useage, the parts wear down and die. Some more quickly than others. I would call the place from where you purchased the refrigerator, or the manufacturer, to see if you are under warranty. You dont really want to make repairs yourself because you dont want to make the problem worse. Also, working on it could somehow void a warranty. (You never know what they hide in the fine print)
Worst case scenario, i would pay a local repair man to fix it.
  • 3,037 Answers
Yes, most likely it would be the pump. Have you checked to see if it feels like it is running. What kind of help are you looking for exactly since it seems you have a bit of knowledge on what is wrong.
please let me know, thanks
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri May 12, 2008
    Have you felt to see if the pump is running?
  • Benjamin Patri
    you basically just need to feel the pump and see if it feels like it is pumping a good rhythm, if not, then you need to replace it. Pretty Simple if you like to use tools
  • Benjamin Patri
    ok, then the pump is most likely fine
    Listen for the freezer fan inside the
    freezer. When the freezer fan is running, it means the defrost timer
    and the cold control in the refrigerator are both set to cool.
  • Benjamin Patri
    ok, well there will still be a fan in the back that should be running towards the top where some air slots are
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Freezer is all frozen
One solution:
This can happen if door has been left open. To solve:
Oct 28, 2013 | Samsung RF265AA Bottom Freezer French Door...
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Warning light
Aug 04, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Frigidaire RL6003B Fridge - running constanly
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Frigidaire Refrigerators
The hole at the back of fridge is not letting water go down so i have puddles of water running to front of fridge have tried cleaning out but just the same
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 14, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
For a couple of days now, my Frigidaire RL6003B small fridge ,the compressor keeps running all day and night and does not switch off. I have felt the compressor and it very hot. The fridge seems to be...
it is possable that a thermostat or sensor is faulty or perhaps the compressor is low on gas you will probably have to call service engineer
Sep 27, 2009 | Refrigerators
We have water accunulating at the bottom of our fridigaire RL6003B fridge
is there a gulley towards the bottom of the back wall with a drain hole in it?
if so, this drain is blocked. push something flexible down the drain till water flows away freely
Sep 07, 2008 | Frigidaire Refrigerators
Refrigerators Logo
1,275 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
