Question about Olympus FL-36 TTL Flash
Non-syncing Olympus FL-36
Ihave 2 Olympus E1's and 2 FL-36 flas guns. When recently using both cameras at a wedding I became aware thate the flash on one of the camera's was not syncing with the shutter. I switched the guns over and established the the fault was in the gun NOT the camera. The faulty gun fails to sync on an E500 as well. I have discovered that it will sync if the gun is set to MANUAL or AUTO mode but not if set to TTL Auto or FP TTL Auto modes. Furthermore, if the camera is set to a long manual shutter speed the flash still does not register any exposure. From this I have concluded that the gun must be firing BEFORE the shutter is open. As I assume that the sync contact is controled by the shutter travel and that three cameras that work perfectly with my other FL-36 are obviously not to blame, I am intrigued as to how the gun can fire prematurely.
Any help with this would be very appreciated, Thanks in anticipation, Ray.
  • 3 Answers
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
Posted on May 11, 2009
1. my olympus E-1 camera does not capture images whet shut. \r
i think that for the E1 you should have the fl 36 ore the fl 50
look in the camera manual it probaly says that you can't use the fl 40
Aug 12, 2009 | Olympus E-1 Digital Camera
FL-50 Repair
Here is the part that you need.
http://www.uscamera.com/cgi-bin/cart.pl
It will take some fiddling around with very small parts to get that installed.
Or you can send it in to Olympus- I know a couple of people that have been charged ~$50 for the repair and Olympus also reconditions everything as well.
Cheers.
Aug 28, 2008 | Olympus FL-50 TTL Flash
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Connect these external flashes...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable - this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Connect to external flashes
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
External Flash
Yes, but only for the C-770 Ultra Zoom. The FL-20 Flash and the FL-36 Flash are both available accessory flashes that cover a wide variety of lighting needs. The FL-50 is designed for advanced to professional photograhphers who need the greatest light output.
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
5-pin TTL connector for external flash
The 5-pin TTL connector is designed to control the Olympus FL-40 dedicated flash unit (p/n 200596). To use the FL-40 with these cameras, the optional Olympus FL-CB01 cable (p/n 200 664) and FL-BK01 flash bracket (p/n 200 666) must be used. The 5-pin TTL connector can also control a PC Sync flash or strobe system by using the optional FL-CB04 flash cable (p/n 200 661). Since this type of flash/strobe is non-dedicated, the photographer will need to manually match the flash output with the camera.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
External Flash
Yes, the FL-20 Flash and the FL-36 Flash are both available accessory flashes that cover a wide variety of lighting needs. The FL-50 is designed for advanced to professional photograhphers who need the greatest light output.
Aug 29, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Open Questions:
Olympus FL-36 TTL Flash Logo
332 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
