Question about Car Audio & Video
I have problems my tevion car cd/mp3 radio model no 41426, when I put a cd in it wont play and just hangs in loading mode. The player is only 6 months old and has a 3 year warranty.
SOURCE: kd-g322 error code query
I unpluged all the wires for one more time and it works again!!!
I think the problem is that one or some wires are damaged because they are pressed between the unit and its case. I also shaked them up and down and for now, it is ok. Try it!!
If this works for more than one day, I' ll let you know...
Posted on Feb 23, 2008
SOURCE: I need an instruction manual
Go to http;//audio.manualsonline.com
Posted on Jul 01, 2008
SOURCE: about every 2 months our
I had the same problem i just decided to pull the whole thing out and get a new radio and single disc cd changer put in and so far it works fine.
Posted on Aug 01, 2008
SOURCE: CD Player in Acura TL 3.2 2003
It's not that hard to fix it yourself.
for your 2003 TL
1. first remove the CD player (this is the hard part).
2. with the CD player removed, unscrew the top cover (4 or 5 screws) on the CD player.
3. with the top cover removed you can see the stuck CD.
4. all you have to do now is just push the CD out and reinstall
should be the same for your 04 TL but im not sure
Posted on Mar 24, 2009
SOURCE: Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
Posted on Apr 05, 2009
6 disc CD player won't play, eject a loaded CD or load a new CD
You may have to remove the radio and disassemble it remove the jammed CD. Unfortunately, there is no easier solution for the problem.
Aug 31, 2016 | Car Audio & Video
Where can i get a wiring plug or photo of plug so can make one up for a tevion 41426 car radio as the original plug is missing (it has 20 pins)
You must see your dealer for a spare cable if available, to install your unit here is a video instruction for installation. http://www.youtube.com/watch?v=RIPpTk8eBmw&feature=player_embedded#.
Feb 05, 2011 | Car Audio & Video
Can i play mp3
Yes it does.....I have included a full list of specs for you for this model
  • DVD/CD player with navigation and built-in amplifier (15 watts RMS/50 peak x 4 channels, CEA-2006 compliant)
  • fits double-sized (4" tall) dash openings
  • motorized 6.5" LCD video screen with adjustable display angle and touchscreen controls
  • plays CDs, CD-Rs, CD-RWs, DVDs, DVD-R/RWs, and MP3 discs
  • GPS navigation (includes GPS antenna and map DVD-ROM)
  • City View mode - 3-D maps that render accurate representations of specific buildings in many cities
  • 6 million points of interest (hotels, restaurants, gas stations, etc.)
  • customizable route preferences
  • separate CD and DVD slots
  • five soundfields: cathedral, club, concert, live, theater
  • 9-band parametric EQ
  • 5 preset EQ curves
  • SIRIUS Satellite Radio-ready (you can add SIRIUS for under $100, plus subscription)
  • compatible with Eclipse HD Radio™ tuner
  • CD changer controls
  • audio/video input
  • rear-view camera input
  • audio/video output
  • 5-volt front, rear, and subwoofer preamp outputs
  • AM/FM tuner
  • 6 FM/6 AM presets
  • warranty: 1 year
Oct 08, 2010 | Eclipse AVN5500 Car DVD Player
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
My cd player keeps saying error 3 what does that
its because of data memory corrupt.. u might need to flast your memory of ur cd player
May 28, 2010 | Aiwa CDC-MP3 CD Player
MY UNIT WONT PLAY CD'S
are they store bought CDs ? or are they copies? cause some players unless stated will not play MP3 or MP4 cds, or CDRs , CDRW Etc.... check if the Cds are burned copies, and then also check the music layout if copied, using the computer, see if they are mp3 files that should play if they are mp4 then the cd will act blank....hope this helps...
Jun 28, 2009 | JVC KD-SX950 CD Player
LG car CD, MP3, WMA Receiver wont play or eject CD's??
please observe when you push the eject button display applys the open or eject cd?.if yes something wrong with your mechanisum.it has several microswitches and bad contact of them occur this type problem.sometime loading mechanisum stuck because of loose belts.open the cover of your cd player and check cairfully.
come back with results.
nuwan
Jan 08, 2009 | Car Audio & Video
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
PACKARD BELL CD/RADIO/MP3 PLAYER. MODEL PB OP 10
This is not for connecting an MP3 player, but rather for playing MP3-CD's. Using your computer and a CD burner, you can burn a CD with up to about ten hours worth of MP3s on it. The procedure for creating the disc varies depending on your burning software. In Nero, for example, you would select "Music" and then "MP3 Disc" and then select the songs you want to put on the disc. For other software you just select "burn a data disc" and then select the MP3 files you want.
Once you have a CD full of MP3s, put it in the Packard-Bell stereo's CD player, and you will be able to play all the MP3 files that are on the CD. THe advantage, of course, is being able to put ten hours on one CD instead of only 80 minutes.
Feb 13, 2008 | Audio Players & Recorders
JNC MP3 PLAYER
just bought my jnc mp3 ssf s50k from hongkong jan 27 and on jan 31, it stopped working. wont even turn on anymore. help.
Aug 27, 2007 | JNC Computers SSF-310 MP3 Player
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
