Question about Samsung SCH-u740 Cellular Phone
I have an Alias Samsung phone, I went on settings then i put nam1 and it turned off then it say '' intial programming needed i pressed ok and it say '' enter lock code '' so i did and my lock code is 1414 i put it and it won't let me unlock
Mi samsum esta bloqueado con cuatro digitos y viene de new yorck kiero saber como kitarle el codigo!
Posted on Oct 11, 2010
Unlock samsung r430
Try turning you phone on, press ##626#, select NAM1, press ok repeatedly until the phone restarts. When the phone starts, use the last four digits of your phone number to unlock the phone. This should work.
May 07, 2013 | Samsung Computers & Internet
Need to unlock samsung SCH-R430
try turning you phone on, press ##626#, select NAM1, press ok repeatedly until the phone restarts. When the phone starts, use the last four digits of your phone number to unlock the phone. This should work.
Sep 09, 2010 | Samsung SCH-u430 Cell Phone
My alias 2 is stuck in USB download mode. How do I
My boyfriend has a samsung convoy and his phone does this every time it dies, he fixes his taking the battery out, then he puts the battery back in, and BEFORE you turn the phone back on put the charger in and let it charge for a min or two. Then try turning the phone back on.
Jan 05, 2010 | Verizon Communications Samsung Alias Cell...
Unlock my Samsung!!!
enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to
Sep 05, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Initial programming needed
Dial *228 and press send. Listen for the prompt and press 1 to program your phone. Remain on the call while your phone is programmed (could take up to 2 minutes). Do not hang up until you hear, 'Your phone has been programmed successfully."
Apr 22, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Cant unlock my phone
If you know your original lock code, take it in to your service provider, each code is diffrent and can only be programed manually, if you dont know your original lock code you will have to sacrific all info pics,mess,numbers, etc. by a reset... I can guide you through the steps to erase all if you lost your Unlock code, or switch back to nam1 if you know your lock code, ( when you switch back, if security is on automatic lock, password is required) intial programing code is not your Unlock code.
Apr 03, 2008 | Samsung SPH-M500 Cellular Phone
Network busy/error 2048
I had the same problem with my old phone the Samsung A660. After 45 minutes on phone with Bell Mobility tech support (which did nothing to cure the problem) I fiddled around with the settings abit, and found there is a setting for something called NAM1 and NAM2. I changed it to NAM1 and I was able to access the browser again! I'm not sure though if the U740 has this NAM1 and NAM2 setting. This what to did for the A660:
  • Press MENU
  • Scroll to (7) SETTINGS, Press OK
  • Scroll to (8) OTHERS, Press OK
  • Scroll to (5) SET NAM
  • Press OK
    Options:
    NAM 1
    NAM 2
  • Scroll to option, Press OK to set
Oct 08, 2007 | Samsung SCH-u740 Cellular Phone
Samsung SCH-u740 Cellular Phone Logo
179 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
