Question about Microwave Ovens
Venting from top to back on microwave do you remove metal piece so it can vent out
  • konkey Sep 06, 2008
    When installation was made the cutout was removed for top to outside exhausting. The fan air only exhaust out the front. What else needs to be done? - I do not have the installation directions.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and full model number.
You need to rotate the blower in the back of the microwave, there shoudl be a screw you take out and you can then rotate the exhaust toward teh top
Posted on Oct 30, 2008
Internal fuse
Is this an over-the-range (OTR) microwave oven or a counter-top model? Assuming it is an OTR model, your can get to the fuse by first unplugging the microwave, then removing 2 to 4 screws over the grille vent. Remove the grille vent. Depending on the model, you either slide it to the left a little bit (1/4 inch) then pull it out, OR tilt out the top of it followed by the bottom. Now you should see 1 screw that hold the top of the control console in place. Remove it, then lift up on the control console to get past the tabs, and tilt out the top. Now, depending on the model, you may see the fuse behind the control console, or if it's not there, then remove the 1 or 2 screws that hold the metal grill vent that's located above the control console. Remove that metal grill, and your should see the fuse behind it. Sometimes that fuse blows for no good reason, other times it blows because you have a shorted high-voltage capacitor, or you may have a sticking "monitor" door switch.
Aug 31, 2014 | Whirlpool Microwave Ovens
Need instructions to replace fuse
First unplug the microwave, then remove 2 to 4 screws over the grille vent. Remove the grille vent. Depending on the model, you either slide it to the left a little bit (1/4 inch) then pull it out, or tilt out the top of it followed by the bottom. Now you should see 1 screw that holds the top of the control console in place. Remove it, then lift up on the control console to free it past the tabs, and tilt out the top. Now, depending on the model, you may see the fuse behind the control console, or if it's not there, then remove the 1 or 2 screws that hold the metal grill vent that's located above the control console. Remove that metal grill, and your should see the fuse behind it.
Aug 30, 2014 | Whirlpool Microwave Ovens
Where is the fuse on kenmore microwave
Jun 25, 2014 | Kenmore 63252 Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Can't remove a1985 GE Microwave Mode3l jvm61001 fro0m the wall.
this microwave oven slides out of its casing. here's how: first shut the power to the unit by the breaker from your main panel. on the mw oven remove the underneath rightside vent filter. unplug the large white connector that you see in through where the filter was . Dont break it. its locked and keywayed. next remove the top front plastic horizontal louvered front vent by one phillips screw on each end of the vent left and right. then remove the next two phillips screws you see under where the vent screws were. then remove the 3 shoulder screws underneath the front edge of the case bottom then slide that piece of **** oven out of its casing. I'm sure you will know what to do next. Good luck!!
Oct 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove a sharp r 1481 over the counter microwave
If you are referring to an over your stove combination microwave/ vent system then they are typically secured thru the cabinet above them. Try opening the cabinet directly over the oven ( you may need a step ladder to see the mounting hardware) and look near the front of that cabinet for two screws on the bottom of that cabinet. These two screws go thru the cabinet and support the front of the microwave oven. You may also see the power cord for that mircrowave oven plugged into a receptacle inside that cabinet. Unplug that cord and then begin unscrewing the two screws. ( it's best if you have a helper work with you).. as you unscrew them, the front of the microwave should begin to drop down a bit. Once the screws are removed, you should be able to lift the back panel up a little bit to free the microwave of the wall mounting bracket. Once that is doen, you will be able to remove the microwave. I am assuming that your microwave does not have any vent pipe secured to it. If it does, then you will need to seperate that from the microwave vent on top ( assuming it is venting thru the top) .. These microwaves can be vented in any of 3 ways, thru the top, outthe back or configured to vent back into the room. In any case, you should see ductwork while removing this from the cabinet. Hope this helps you get the job done...
Sep 13, 2008 | Sharp Microwave Ovens
Fan vents
Most microwave oven fan systems can be rotated for either back or top venting.. This can be done by removing a few screws and rotating the blower housing to the position you need and screwing it back in place.. Hope this helps..
Aug 30, 2008 | GE Microwave Ovens
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
Microwave Ovens Logo
105 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
