Question about Gateway MT6821 Notebook
I need to remove the back to my gateway my6821 to expose the dc jack...my computer just stopped powering up. I get nothing no fan no light nada
The solution I've found is simple.
No need to disassemble computer.
The DC jack will over time crack the solder on the center pin through the pc-board and lose continuity.
First remove the keyboard cover by removing 2 screws (on rear under hinges) and gently prying upward beginning at hinges. Directly under where the power button was and beside the actual power switch find the solder connections for the DC jack. (The jack is on other side of board. You are seeing the bottom of board).
Examine all jack connections for cracked solder around the pins. a magnifying glass helps. Usually it is just the center pin which is toward the rear of the jack, obvious cracking causes intermittent connection or no connection.
If you have no experience soldering I recommend you leave this task to someone who does.
Carefully apply rosen core solder to pin(s) using proper fine tip iron. heat thoroughly til pin moves in hole then apply fresh solder. Be quick. Not too much solder, not too much heat. Be careful not to allow iron's barrel to touch plastic case or tip to build solder bridge to any other connection.
Problem solved.
jamespaulhunt@yahoo.com
Posted on Dec 03, 2010
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
Access to solder joint Gateway MX6440
Hello. I have seen this happen with all models of laptops. Too bad Apple has a patent on that magnetic power cord they use...
You can find all of the service and user manuals for your Gateway laptop here...
http://support.gateway.com/support/manlib/Notebooks/notebook.shtml
Dec 03, 2009 | Gateway MX6440 Notebook
Pavilion dv7 starts up then shuts down. If I remove the power cord and plug it in right away I get nothing. No light at dc jack or on the front of the laptop. If I wait a wile I some times can get the...
This sounds like you have a bad DC jack on your motherboard. This is one of the most common problems with laptops and can be caused by jarring the DC plug in or hitting it into something or simply from normal use. As a result the pins on the DC jack become loose and consequently do not provide a charge to the laptop and battery. Wiggling the plug can make the loose pins contact sometimes which would explain why it "sometimes" works when you unplug it and plug it back in. Of course if this is the case then your battery is mostly out of power and that is why it powers off after a couple seconds. This repair costs between $150-300 from a professional repair shop and I would not recommend trying it yourself unless you've had experience soldering DC jacks
Another issue could be the CPU fan/heat skin if this is failing or the CPU is overheating the laptop will power off.
Please comment if you need further assistance
Nov 21, 2009 | HP Pavilion dv7-1245dx Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Vaio will not turm on
you will most likely need to replace the dc jack, which is the port where your charger plug plugs into...
To test if your dc jack is bad... Remove the Battery, Plug the Power cord into laptop then attempt to power on... If no lights turn on, no fan spins.. your DC jack is bad...
DC Jacks Cost $6 to $10 but you need to find someone experienced to replace it, or you might end up with a dead motherboard as well..
Oct 14, 2008 | Sony VAIO PCG-V505DXP Notebook
Power problem
You need to remove the screws on the bottom of the laptop. Once the right screws are removed the case will seperate exposing the MOBO and that and you should see the dc jack (power jack) as forwarning, almost ALL dc jacks are sodered to the motherboard..and not easy to successfully replace.
Jul 24, 2008 | Averatec 3200 Notebook
No power when i start vaio pcg k45
Recheck the small flat cables coming from the power button panel to the systemboard.
Jan 23, 2008 | Sony VAIO K45 Notebook
Computer won't reboot
Hi, I can help you with this. What shows on the screen when you power it on?
Sep 10, 2007 | Toshiba Satellite M35X-S111 Notebook
Gateway MT6821 Notebook Logo
200 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
