Question about Maytag MGS5870 Gas Kitchen Range
I ahve a maytag mgs5870 adc. Oven will light then go off and on.
  • Maytag Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 07, 2010
Stove won't light, gas is not getting through
the valves could be bad. since you did not give much detail i'd go with this: the valves could be bad. have the ones involved replaced by a quilified repairman.
May 08, 2011 | Maytag MGS5870 Gas Kitchen Range
Lower burner in oven does not light. Igniter glows
heatman101
Nov 16, 2010 | Maytag MGS5870 Gas Kitchen Range
No gas to oven
The gas will not go on in the oven unless the ignitor is working as it should.
Remove the bottom panel of the oven so you can see the burner tube. Turn on the oven and watch the ignitor. When the ignitor starts to glow it should get a really bright almost hard to look at glow. If it just turns red then it is not pulling the correct amperage to let the valve know to release the gas.
Replace the ignitor and you should be good to go!
Apr 03, 2010 | Maytag MGS5870 Gas Kitchen Range
Need a new oven door
Hi and welcome to FixYa. I am Kelly.
Your model is missing the last few digits i.e AD____
(fill in the blank)
It should be: MAYTAG MGS5870AD___
Mainly for reasons of color
Your oven door has to be rebuilt piece by piece. You can find all of the parts at the link below but, make sure you have the right model number before ordering.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46716&diagram_id=661885#d661885
If I can be of more assistance to you just reply here. We get notified of any responses and I will respond accordingly.
Kelly
Feb 09, 2010 | Maytag MGS5870 Gas Kitchen Range
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
NoT A GOOD SEAL ON THE DOORS
check the light switch itself
check the door switch
Oct 03, 2009 | Maytag MGS5870 Gas Kitchen Range
OVEN NEVER REACHES TEMPERATURE SETTING
I read my wonderful "user's guide". In the section, Controls at a Glance, I found OVEN TEMPERATURE ADJUSTMENT OPTION & followed 5 easy sets. It worked!!!
Nov 11, 2008 | Maytag MGS5870 Gas Kitchen Range
Maytag Gas range
We had the same thing happen and had the Atco Gas company come out to look at it.  Our regulator was not working properly which caused CO to be relased.  We were told that the problem could be fixed for about $250-300 (CAN.) including parts and labour.
Jun 09, 2007 | Maytag MGS5870 Gas Kitchen Range
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Maytag MGS5870 Gas Kitchen Range Logo
77 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
