Question about Whirlpool Washing Machines
My whirlpool washer doesn't drain/spin what's the problem?
    President:
  • 3,773 Answers
Replace the lid switch
Don't forget to check the plunger on the door lid for broken.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 05, 2010
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
I have the whirlpool model WTW495OXWD and it wont spin or drain,
see this causes:
drain line is clogged fix it,some sock is inside, take pliers and remove, if you can you need to remove the agitator, the propeel of pump can be defective replace.
frozen pulley pump replace
improve the drain line. if mayor that 4 inch cut of the diference, is a lower install air/gap siphon break assembly
Jun 21, 2012 | Whirlpool Washing Machines
Draining but not spinning
if it doesn't spin or agitate but you can hear the motor running check the motor coupling,common problem with whirlpool washers
http://www.youtube.com/watch?v=9K1KHEogf3c hope this helps and good luck with your washer,or you could have a bad transmission but check the coupling first,part 285753A and it's around 20 dollars
Mar 04, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
What can I do to get my WP Cabrio washer to drain & spin?
Your drain hose has to be higher than the water level in the tub, almost up to the top of the tub
Dec 30, 2011 | Whirlpool Cabrio WTW6600SBK
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water doesn't drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 08, 2011 | Whirlpool Washing Machines
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
Washer tries to spin but stops after afew seconds
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 17, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
32 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
