Question about Canon PIXMA iP5000 InkJet Photo Printer
Hello everybody my problem is, my CANON IP5000 stopped to work and flash 5 times orange and one green. also write ' fault of operator' (translation from Greek to English) thank you Mihalis Papadakos
  • Canon Master
  • 4,737 Answers
Simplest Trick: Open the front cover, pull the cartridges with the carriage and leave them somewhere on the passage, now close the cover and turn off the printer, again turn it on. If it's not a fatal error, there'd be no more problem and no more error displays on the screen.
First try this, open the hood (front cover), after the cartridges moved towards the other end/side, look at the other side (the side where the cartridges were sitting before it moved to the other side). You'll see the Waste Ink Tank Pads (sponge), remove them and clean them (they should have been soaked with ink, so use a hand-glove). Remove the pads and squeaze or wash and dry them, after they are cleaned and dried, reinstall (re-seat) them. Now power on the printer and check again.
Secondly, (remove the cartridges before you begin) open the doors and look for paper jam or anything inside the passage and through the paper passage. Use a blower to blow all the dust and clear them out. Now turn off the printer and leave it for few minutes while you clean the cartridges, again switch on the printer, install the cartridges. Now see if it's still there or not.
Try turning the printer up-side down, shake it (do this while the machine is off) and again reboot it. Once again check the status.
Push in a photo paper (or similar thicker paper) into the sheet feeder, do this several times and again reboot the printer.
If the problem persists even after all these are done, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 05, 2010
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
Canon pixma IX4000 printer orange led 5 times blinking.pls send how to solve this problem.
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
  2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
  6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Jul 06, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Hello , I'm using Canon MP160 for windows XP bit 32 ... I can't scan or print ... The printer flashes E22 .. What should i do ? healp please .. thanks !
E22 means cartridge error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
May 17, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Ella@hotmail.comI have 6 orange flashes to one green on a pixma ip5000 whaty is going on?
Hi
Please check your Printer Cartridge and check any paper jam is there, paper jam is there please remove the paper. and restart your printer.
Good Luck
May 11, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
I have a Canon Pixma IP 4000 and keep getting the error message that the ink absorber is nearly full. Print quality is not good even after cleaning. What should I do?
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My printer flash green then oranfe and again and
5 times says the feed roller is not turning properly, sometimes the gears break and other times something falls in the back and stops the roller from turning. It's a different error if the orange flashes 5 times, or if it flashes orange and green 5 times.
Sep 01, 2009 | Canon BubbleJet i560 InkJet Printer
Waste ink tank full, what do I do?
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
Aug 02, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Printer power light keeps flashing green and yellow
Depending on how many - 5 orange = print head malfunction - not fitted correctly or more than likley the ribbin cable is broken or burnt out. £50 for new one.....
Sorry!
BigHSg
Dec 19, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
118 people viewed this question
old marine
old marine
