Question about Mirage FRX S8 Speaker
I don't get any sound from the sub woofer of my Mirage FRx-S8 surround sound system - how can i tell if the fuse is blown and where can I get a new one if it is? Thanks
SOURCE: sub woofer keeps blowing fuses
Try a 3 amp fuse
Posted on Jun 24, 2008
SOURCE: Sub woofer amp blown
looking for a replacement amp for mackie srm 450 woofer
Posted on Nov 14, 2008
  • 8 Answers
SOURCE: replaceing internal fuse to mackie active sub woofer swa 1501
Hi There, you need to check the 3 fuses that clip onto the main amp board. You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these by pulling out the burnt out fuse and replace with a new fuse and hey presto you should be back up and running. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Also the offer a service of swapping them over for you if you really don't want to do it yourself. Hope this helps. Grant (from www.LondonSpeakerHire.com)
Posted on Mar 24, 2009
SOURCE: Blown driver
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=297-460&ctab=2#Tabs
Posted on Oct 04, 2009
Nomodo4u
  • 863 Answers
SOURCE: Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Posted on Feb 15, 2010
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
I just got my system today. All the speakers are working, except the sub-woofer. Any ideas what could be wrong (if not DoA)?
Did you connect power to the sub-woofer? Most subs have their own amplifier. Just check if there is also an on / off switch on the sub.
Apr 18, 2015 | Frisby 5.1 Surround Sound Home Theater...
Schematic
i have same isue humming like hell ,change 2 power supply capasitor didnt do it ,try to changer 2 mosfest transistor Samsung IRF640 N-channel MOSFET TO-220 200V 18A hope it will do it ,on ebay for a 2.00 each .
i think it is power supply isue ,recterfile circuit not clean it will give you that 60hz humming noise ,good luck
will let you know how it turn out ..
Jul 14, 2013 | Mirage OMNI S8 Speaker
Blown Nanosat speaker
It's not hard to replace the woofers on the small speakers (these are usually the only thing that goes out). The subwoofer may be more difficult to repair.
May 28, 2013 | Mirage NANOSAT 5.1 System System
I have a Mirage Prestige S8 subwoofer. 4 years old. Suddenly nothing....not functioning. No change in usage or location. Any ideas?
Check the status indicator - The LED found on the front panel should be illuminate in blue when the subwoofer is functioning. If the unit is in Auto mode and is not receiving a signal, the light will remain off. Try setting the power switch on the back to ON if in the Auto setting. Post back the status of your LED.
Aug 31, 2011 | Mirage Prestige S8 Subwoofer Speaker
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Mirage s8 subwoofer is emitting a constant hum
that is just the radio from the input,its normal
Jun 19, 2010 | Mirage Prestige S8 Subwoofer Speaker
Mirage LF 150 Sub Woofer. sub not working
within the sub amplifier is an electronic amplifier, that is shorted and blown a fuse. This is all internal. If you can dismantle this module, I suggest do so and any electrical/electronic individual will identify the part needed. you could also check on a replacement module-complete.
Mar 04, 2010 | Mirage LF150 Subwoofer
Jvc th-s8 no sound
There is a stock fault on the sub woofer unit.
R2702 fusible resistor is likely to be faulty.
Here is their modification - dodgy english but you get the idea.
Reasons: R2702 (QRZ9005-470X) a 47 Ohm 1/4W resistor is open circuit due to rush current at the time of
power supply ON/OFF.
Cure: 1) R2702 change value : QRZ9005-470X --> QRJ146J-220X
2) C2704 change value QETN1EM-107Z --> QETN1HM-476Z
Sep 28, 2008 | JVC TH-S8 System
Surround sound
How do I hook-up my surround sound system with powered sub woofer to my Sony stereo receiver and sony dvd player?
Sep 19, 2008 | Sony DAV-HDX500 System
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
Rob
Rob
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
