Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Sending a fax
I have no instructions to send a fax. I thought I sent one and the recipient said they did not get it.
  • 832 Answers
Issue too much complex. plz read faq and the manual:
http://welcome.solutions.brother.com/bsc/Public_s/index.html
choose your country and then your mfc. read faq and download manual.
Posted on May 13, 2008
My faxes are going through but I get error tx reports. Why is this?
because the fax is not going through as transmitted
the fax report will have OK if it was sent and received correctly
call the recipient of the fax direct and ask what the fax looks like or if they got it alright
Oct 24, 2016 | Office Equipment & Supplies
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
Need instructions on how to send fax, it seem as though we are not following the correct steps
Solution: Sending faxes on an MX310
Sending Faxes
The operation flow of sending faxes is as follows.
  1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
    Platen Glass
    1. Lift the document cover (1).
    2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
    3. Gently close the document cover.
ADF
  1. Remove any documents from the Platen Glass.
  2. Open the Document Tray.
  3. Load the document in the ADF.
    Load the document with the side you want to copy, scan, or fax facing up in the ADF.
  4. Adjust the Document Guides to match the document width.
  1. Press the button.
  2. Adjust fax settings as necessary.
  3. Start faxing.
    1. Dial the recipient's number using the numeric buttons or coded speed dialing.
    2. Press the button for color sending, or the button for black & white sending.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
    3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
    4. If you have only one page of document to scan, go to step 5.
    5. Press the same button as you pressed in step 4b.
    6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
  4. Press the button.
  5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
  2. Press the button.
  3. Press the (left) or (right) button to select the contrast.
  4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
  5. Press the button.
Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
  2. Press the button two times.
  3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
STANDARD:
Suitable for text-only documents.
FINE:
Suitable for fine-print documents.
PHOTO:
Suitable for photographs.
Return to Start Faxing
Back to the Top of the document
Dialing the Coded Speed Dial
  2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
  3. Press the button for color sending, or the button for black & white sending.
    Note:
    * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
Feb 04, 2011 | Canon PIXMA MX310 All-In-One Printer
How does I fax something from my Canon MX320?
Follow these steps :
Prepare the document that you want to fax.
Prepare a fax cover sheet, if desired.
Open your fax software - such as Microsoft Fax or Microsoft Exchange.
Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5
Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6
Indicate whether you wish to send a cover sheet.
7
When asked to attach the file, follow instructions to attach the file that you want to fax.
8
When ready, click Send. The fax will begin to compile the information and, when ready,
9
When the connection is made, the fax will be sent.
Oct 26, 2010 | Canon Office Equipment & Supplies
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Dec 08, 2008 | Office Equipment & Supplies
How do I fax?
Sending a fax from your computer requires a fax modem and that your operating system be configured to allow you to send and receive faxes.
to send from fax software
step 1 Prepare the document that you want to fax. Step2 Prepare a fax cover sheet, if desired. Step3 Open your fax software - such as Microsoft Fax or Microsoft Exchange. Step4 Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item. Step5 Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed. Step6 Indicate whether you wish to send a cover sheet. Step7 When asked to attach the file, follow instructions to attach the file that you want to fax. Step8 When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine. Step9 When the connection is made, the fax will be sent. To Fax From Your Word Processing Program Step1 Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software. Step2 Open the document that you want to fax. Step3 From the File menu, select Print. The Print window opens. Step4 Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print. Step5 You will be asked to provide the recipient's fax number and other assorted information as with a fax program. Step6 The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
Aug 26, 2008 | Computers & Internet
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
