Question about Eljer 141-0220-00 Toilet Tank White
What kind of flapper replacement fits - Eljer 141-0220-00 Toilet Tank White
Replace broken flapper in lint screen slot.
it has been a while since I worked on one of these but if I remember there are 5 screws to remove 3 on door opening on front and two that r on back side of screen holder that have to be removed then u can take the whole thing out to put new flapper in.
Apr 08, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Tip
How to fix a flush valve
  • Most toilet tank troubles can be traced to a faulty flush valve. You have three choices in correcting this common problem: (1) repair the old flush valve; (2) replace the flush ball with a more modern flapper or install a glued-in replacement flapper; (3) or install a new flush valve.
  • These repairs require a varying amount of work. The more simple adjustments were discussed previously.
  • Examine the old flush ball or flapper. If it is aged or encrusted with deposits, replace it with a new one. Scale deposits on the seat can be removed with steel wool or with No. 500 wet-or-dry abrasive paper. But if the valve still leaks, it must be replaced.
  • You can install a new guide arm, if necessary. To remove the lift wire from a flush ball, turn it counterclockwise with pliers. If you are replacing all parts, simply cut off the old lift wire.
  • Flapper. To replace a flapper, disconnect the lift hardware from the trip arm and slide the flapper up and off the overflow pipe. Install the new unit, reversing directions, and connect the lift hardware back to the trip arm. Any excess lift chain can be cut off or left dangling, if it doesn't interfere with toilet operation.
  • A loose trip handle can be fixed by tightening. The nut has left-hand threads, and must be turned counterclockwise to tighten (looking from inside the tank). Or, you can install a replacement trip handle.
  • Glue-in repair kit. Many replacement flush valves simply glue in place on top of the old valve seat. While several brands are available, not every type of flush can be replaced by these devices.
  • On single-piece toilet tanks–with a flush valve held in place with flanges that fit inside the opening–the flapper-ball may bind and prevent a leak-proof seal. On more common two-piece toilets, this problem does not occur.
  • Using a glue-in repair kit is quick and easy, but you must follow the manufacturer's instructions. To be sure you purchase the right kind of repair kit, take a rough drawing of the bottom of your toilet tank and flush valve to your hardware or home center store.
on Jan 16, 2010 | Plumbing
This flapper seems to be a desige failure. what product is a good alternative.
universal flappers fit all different ways you may have to cut or alter the tabs or o-ring to make it sit right also check chain is set right
Apr 03, 2014 | Fluidmaster 5403 3-in Universal Flapper
It requires so much force to flush my toilet that I have replaced the lever 6 times in the last few years. There is a vaccum like resistance. What can I do?
I am going to take a stab at this with the information you have provided. If you have replaced the flapper around the time this hard flushing deal stated happening I would say the flapper is the wrong kind for this toilet. Flappers are not one fits all some have a bigger air cavity to help with the flushing process. The larger air cavity help buy floating the flapper up after it is started that way. If you didn't change flappers then I would do so at this time making sure you install the right one.
Feb 10, 2011 | Mansfield Plumbing Products Home
I'm pretty sure i need a new flapper but can't find one specifically labeled for kallista michael Smith Town toilets when I search for parts/flappers. Can you suggest another brand toilet whose flapper...
Hello, I can assist you. The flapper part number you need for replacement is GP1078440. You can purchase this item from any of our authorized locations. To find a showroom location near you please visit www.Kallista.com or call our customer service team at 1-888-452-5547.
Oct 02, 2010 | Kallista Michael S Smith Country Mahogany...
I have a kohler one pease model K-3434 I Have replaced all parts kohler parts the problem i had before was the flapper was not sealing properly after replacing all parts i still have the same problem...
Try cleaning the surface of the drain hole where the flapper fits. There might be crud causing it to not seal. Sometimes the flapper itself is not large enough (or too large) to properly fit the hole. If no good you might try weighting the flapper. Not easy to do. You'll have to pull the flapper, dry it completely find the right adhesive place the weight just right. And hope that works. Good Luck...
Aug 23, 2017 | Kohler - Toilet - One-piece - San Raphael...
How do you remove or replace the flapper.
Your leak is most likely caused by either a worn flapper or a worn valve seal. Best bet is to replace both as the coat for a new valve assembly and flapper is about $12 at Home Depot. Look for the Fluidmaster display in the plumbing department. Easy to follow instructions are included. Since you have a one-piece toilet you'll need to be sure that it will fit so measure the depth of the tank.
Jun 02, 2010 | Eljer Toilet Onepiece Canterbury ...
I have a jauzzi 1.6 elongated toilet. I bought it in 2008. the flapper broke and I replaced it with a universal one. the only one i could find to fit it. Every time I flush the toilet, the flapper comes...
You're going to have to get the correct flapper for that toilet. Also, make sure that there is not something broken on the side that the flapper keeps coming disconnected from.
Oct 20, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Small streams of H2O down interior sides of commode bowl. Have replaced flapper and color tested for leakage,Nada, replaced ballcock fill assembly with Fluidmaster unit and still getting very small...
this is still the flapper.each toilet has a flapper designed to fit each toilet.your may not have the right flapper for the toilet you have.not all flappers weights are the same.youmay need to add some weight to the flapper or replace it with one that is designed for that model toilet.good luck with your project
Sep 29, 2009 | Home
Eljer 141-0220-00 Toilet Tank White Logo
194 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
