The TV is only showing half of the picture I have a Panasonic TX32 PL10 100HZ tv. I havent moved or banged into it but am getting the same problem as above. My tv turns on ok if left for a while, but after a few minutes it loses the top half of the screen with a white line where the two join. The picture does not move or flicker.
  • Anonymous May 20, 2008
    screen is black in middle
    Champion:
  • 230 Answers
Resolder vertical IC. (loose connections!!!), Ready!!!
Posted on May 13, 2008
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TV picture shrinks to a line
There is an IC which controls the vertical deflection and over the course of a few (or 8) years with the set heating up and cooling off some of the connections work their way loose causing the symptoms you describe.
If you were to bang on the side of the set you could likely "pop" it back in but this is not a good solution. The vertical IC needs to be re-soldered. This is especially common in Panasonic sets. About 10 minutes with a soldering iron should have it worked out.
If you're handy with a soldering iron I can tell you what to look for.
Oct 09, 2008 | Panasonic CT-32G14 32" TV
Hi, my Panasonic LCD TV model TX32 LXD52 is showing red with glittery effect all over the screen and picture, could anyone know which panel is faulty and where to get one, please help, see the video...
what happens when you have the menu on the screen could be the screen driver or the picture control control board. would depend on the menu display.
Oct 03, 2013 | Televison & Video
How do i connect my tv aerial to the panasonic tx-32lxd1? Do I need a dvd player to connect the aerial to. If so, it appears like I have to use a dvd palyer with freeview (the cheaper dvd players do not...
No, you plug it in directly in the antenna socket at the rear of the tv.
http://www.avforums.com/forums/attachments/lcd-led-lcd-tvs/12427d1113566868-panasonic-tx32-lxd1-lxd50-scart.jpg
You just need a special connector if you have the australian model, like in the picture above. Otherwise it just plugs in as explained in the user manual. If you need the manual
http://diplo-best.com/314.php?k=2e82a812e1d673595f5f6fcff561ba40&ID=199713&q=PANASONIC%20TX-32LXD1
Jul 03, 2011 | Panasonic Televison & Video
TV Picture Pops In and Out Toshiba Color TV CZ27V51
mine was doing the same thing. If i put pressure on the cable input from left or right it would fix this.
May 22, 2009 | Toshiba CZ27V51 27" TV
White dashes across top left of TV screen
That is what I was going yo suggest. You can also adjust the picture size. "Just" will show all of the picture even the distortions on the edges. "Full" will in effect overscan and trim those edges off.
Apr 27, 2009 | Panasonic SC-DT100 System
Tube TV-sound ok, no picture sometimes
You do have a loose connection, you can take the back off and try to look for a cold solder connection or a crack someplace on the circuit board. In any event the section to concentrate on is the HV section of the TV.
I wish you well in finding the connection. You will need a soldering iron and solder once you find the problem.
One other option is that you can just donate the TV to a vocational school and get a tax write-off for next year.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 06, 2009 | Panasonic Televison & Video
Sony tv problem
You have a loose solder connection or two. If I knew the model number of the set, I could be more specific. I would expect the repair would run about a hundred dollars, so make sure the picture quality is great before going to the expense.
Aug 02, 2008 | Televison & Video
Panasonic 50 inch plasma tv
It's hard to say without seeing a picture. Panasonic has a site with pictures of various Plasma symptoms and the board that will cause that problem. Go to: http://www.pasctraining.panasonic.com/PASS/elearn/PDP.htm Click on: Pictures of plasma symptoms It will direct you to a PDF file. It may not be your exact problem, but, it will show you which board will cause your problem. Hope this helps.
Apr 21, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Feb 03, 2007 | Panasonic CT-34WX54 34" TV
Televison & Video Logo
239 people viewed this question
Top Televison & Video Experts
