Question about Whirlpool Refrigerators
The drain plug in the freezer continually freezes up. Once thawed and the tube to the floor drain pan opens up it freezes up again within a few weeks. This of course causes water to drain into the refrigerator section. How do I permanently keep the plug from freezing up?
  • 4,793 Answers
Syringe it out with neat clorine bleach,that will clear it out........as clorine is a gas the smell will go within 30 mins...
Posted on Sep 05, 2010
Ice Build up on freezer floor then leaks out the front on to the floor. Drain tube is not plugged. The ice builds up in the drain trough then over flows on to the floor of freezer.
Not usually, will have to thaw, then run pan of hot water through drai. Can pull lower vent cover off to make sure it runs into drain pan under fridge. Drain may look clean but tube may not be. Can take wire from hanger to clear as well.
Sep 29, 2015 | Refrigerators
Clogged drain plug
Happens to me too. The drain freezes, freezer floor freezes and then ice starts building up to the point where it forms in the fan area and then the blades hit the fan and it gets very noisy. In my case, the container that is supposed to carry the defrosted water to the drain has a electric wire running underneath and twisting around the drain hole. I believe this wire is supposed to heat up and melt the ice to stop the drain hole from freezing. I believe the heating mechanism has failed in my case and suspect the same for you. Until fixed, this will continue to freeze up every so often. Search for your LG freezer drain heating element or parts.
Mar 13, 2014 | LG Refrigerators
Water is dripping from freezer to shelves in fridge
first remove the floor and back wall of the freezer. remove the ice from the floor and drain pan careful not to damage the evaporator and drain pan. to the right of cener on the bottom of the drain pan is the drain hole. use a turkey baster and hot water to thaw the drain, you should hear water dripping into the drain pan when thawed. install a heat probe whirlpool part number 819043. or wrap a thick piece ( about the size of a pencil lead) of copper wire around the heater located under the evaporator. make it long enough to go about 2 inches into the drain. don't let the wire touch the sides of the drain hole or touch the bottom of the tube, this will prevent the drain from freezing. i recommend using the heat probe from whirlpool but the wire will work too. hope this helps.
Jan 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is accumulating in the bottom freezer and freezing...I continually have to chisel it out. We have tried defrosting it but have the same problem a few days later.
Hi.This will normally be caused by a clogged drainage hose or plug. There is a drain leading out of the freezer and another from the refrigerator. In top freezer models, the freezer may drain the water onto the back wall. It actually runs down the wall to the refrigerator floor drain. In other cases, there may be a drain tube leading out the freezer. The refrigerator drain is either located on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel. In side-by-side models, the freezer and refrigerator will probably each have an outlet to the drain pan under the appliance.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Dec 09, 2009 | Kenmore Refrigerators
Water dripping on the inside back of the refrigerator and water then freezes at bottom, in and under crisper drawers. Refrigerator is approx 6-7 yrs old and was recently leveled again.
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Jul 26, 2009 | Refrigerators
In the frezzer ice is forming under the floor and dripping down onto the floor of the refrigerator part under the veg drawers
May 05, 2009 | Kenmore Refrigerators
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
Loud banging noise and water leaking
not much can be done about compressore noise, short of replacing it. but your drain issue is easily fixed, with that whirlpool heat strap you mentioned.it actually wraps around the heater in frezer section and the idea is that when the unit goes into a defrost cycle(3 or 4 times a day) the heater heats the strap(which runs into drain tube) up as well, preventing tube from freeezing up and eventually backing up into your freezer floor
Feb 23, 2008 | Refrigerators
first of all the noise is the internal compressor motor hitting the steel shell on shut down. in my experience this is annoying and not really a huge concern as far as the compressor dying any time soon. now your drain problem. i would recomend the wire or heat probe that whirlpool recomends. when your freezer defrosts the water that drips off of the coil can and will flash freeze in the drain area causing it to freeze up a peice of 10 or 12 guage solid copper wire run into the drain and wrapped around your def heater will transfer enough heat into the drain hole to prevent it from freezing up.
fwiw: whirlpool in my opinion is probably one of the best appliances on the market..
Dec 12, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Bottom of freezer icing with thick sheet of ice
you have a froen drain thats why it is allways getting ice on the floor. you need to remove as much as you can then remove the back of the freezer so you can clear the drain pan and clear the drain. its not hard to do just you will have a lot of water on the bottom and your floor maybe. once you remove the ice from the pan have some very hot water and pour it in the pan utill the drain is free and the water go's down into the drip pan. shut the unit off untill tour done and be carefull around the coils. once its clear put the back on and plug the fridge back in. you will now have no more ice build up. make sure there is no food back there that can block the drain either. its a god time to clean the freezer out
Aug 10, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
137 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
