Question about Dishwashers
Caple DI604 dishwasher stops almost immediately after starting. Error code is that the 3 left lights are on when I open the door. Does anyone know what the error code means?
COXY
  • 76 Answers
SOURCE: Electrolux Gallery Dishwasher Error Message AL3
It sounds like it could be a heater problem, I would check this first
Posted on Nov 27, 2007
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
SOURCE: hotpoint bf162 built-in dishwasher error codes
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Posted on Mar 07, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Posted on Mar 24, 2008
SOURCE: error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Posted on Mar 28, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
I have the CW447 integrated dishwasher which won't fill with water
Like most electrical appliances what worked for me was turn it off at the wall for 10 mins, then turn it back on. Did you get an error code? Check the pipes are not twisted and that the water supply is turned on full. Let me know how you get on
Apr 13, 2014 | CDA WC430 Dishwasher
Caple dishwasher stops & beeps continually before finishing 60 degree cycle
Thanks for clarifying the model number. See the user manual at this site. You can download and save it for future.
http://www.caple.co.uk/downloads/manuals/dishwashers/di414-di440_dishwasher-manual.pdf
But I don't think this will help you in the problem. It is very likely that the thermal limiter relay is faulty. It is meant to protect the dishwasher from over heating. It must be cutting before 60deg.
You can see the circuit diagram of a related Capel model on this page.
http://www.caple.co.uk/downloads/manuals/dishwashers/di604.pdf
You can see the part looks like this
http://www.4caple.co.uk/ntc-probe-feeler/product.pl?pid=357313&query=Di414
Apr 12, 2014 | Caple DI60715 Dishwasher
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Thanks!!
Jan 04, 2012 | Blomberg DWT34200 DWT34210 DWT34220...
Program will not start, door light flashing
Has anyone had any joy with this? I have exactly the same problem.
Thanks
May 04, 2010 | Whirlpool AWM8143 Front Load Washer
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Hotpoint bf162 built-in dishwasher error codes
take out diswasher, tip it backwards and drain out water. make sure that salt resovoir is on tight and there are no leaks from the arms
Jan 11, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
F7 error
Raise your water supply temerature. Next open door and within 3 seconds hit hi-temp scrub, then energy saver. Do this again. Close door and latch, then push reset button.
May 22, 2007 | Whirlpool 24 in. ADG7952 Built-in...
F8 Error
F8 code means that washer has not emptied out fully. Open the door,empty water manually, clear the filters and the drains. Close the door and then hold the start button,until it will restart. Good luck !
Mar 27, 2007 | Whirlpool 24 in. ADG7952 Built-in...
Dishwashers Logo
185 people viewed this question
Top Dishwashers Experts
