Tolomeo floor lamp assembly instruction - Office Equipment & Supplies
2009 buick lacrosse console gear indicator bulb
Transmission Floor Shift Control Indicator Lamp Replacement
Remove the front floor console. Refer to Front Floor Console Replacement.
Rotate the floor shift control indicator lamp socket (2). Pull the socket from the trim bezel.
Remove the bulb from the socket.
Preliminary Procedures
Remove the rear floor console. Refer to Rear Floor Console Replacement.
Remove the instrument panel lower trim plate. Refer to Instrument Panel Lower Trim Plate Replacement.
Set the parking brake, then shift the transmission into drive and push the shift indicator down until it locks, to allow clearance to remove the console.
Front Floor Console Screw (Qty: 2)
Caution: Refer to Fastener Caution in the Preface section.
Tighten
2 N·m (18 lb in)
Front Floor Console Bolt (Qty: 2)
Tighten
10 N·m (88 lb in)
Front Floor Console Assembly
Front Floor Console Retainer Clip (Qty: 2)
Feb 24, 2017 | 2009 Buick LaCrosse
Brake lights 2001 Oldsmobile aurora
switch may have failed under dash at brake pedal arm or got unplugged but BIG FEET
Sep 10, 2015 | 2001 Oldsmobile Aurora
Instructions how to pur together
Thank you for your inquiry. For assembly instructions please visit the appropriate website below:
If you are in the US:
http://content.dyson.com/support/help.asp?article=464&product=DC07-SY-HEPA_US
If you are in the UK:
http://www.dyson.co.uk/support/dc07/dc07-all-floors/using-your-dyson-machine/assembling-your-dyson-vacuum-step-1
If you are having difficulty with the assembly or would like additional assistance, please call us at 1-866-693-9766 (US) or 0800 298 0298 (UK).
Best wishes,
Jessica
Jul 31, 2012 | Dyson DC07 All Floors Bagless Upright...
My screen on my tv was dim for about 3 days and then when i tried to turn it on i heard a popping news and it now will not power back on.
The problem of your unit is the lamp, try to replace new lamp follow this instructions. Unplug your unit to main AC outlet, remove the protective panel. The location of the lamp assembly will vary, try to read the owners manual before proceeding. The removable lamp assembly is at the of the TV, either on the back or at the side. Remove the small screws that hold the protective panel in place and slide off the panel. Disconnect the lamp assembly. Loosen the one or two screws that hold the lamp assembly in place. On some units, the screws will loosen but remain attached to the assembly. Hold the plastic handle on the lamp assembly and pull the assembly straight out. Note do not touch the bulb with your bare hands. Insert the new bulb assembly. Replacement lamps are usually sold pre-installed in a plastic assembly. Do not touch the bulb. good day and best regards.
Sep 09, 2011 | Televison & Video
How do I remove the rear brake light cover on 1990 GMC Sierra 2500 to change bulbs? Are there clips inside-specific places to pry it off? Thanks
seddy29732_3.jpg I hope these instructions match your model.
  1. Lower the tailgate.
  2. Remove the lamp assembly retaining screws.
  3. Pull the lamp assembly from the truck and disconnect the wiring.
  4. Remove the bulb holder fasteners.
  5. Remove the bulb(s) from the lamp.
  6. Install the bulb, connect the wiring and install the lamp.
Jun 03, 2011 | 1990 GMC Sierra
Sony color sucks model kdfe42a10 piece of
Please follow the instructions below to check that sometimes the lamp cove does not properly closed,
1. Remove the Lamp Cover.
2. Turn the lock to the OPEN position to release the Lamp Door and remove.
3. Pull out the Lamp Assembly, then reinsert the Lamp Assembly until it is locked into place.
4. Replace the Lamp door and turn the lock to the CLOSE position.
If the problem persists then you have to replace the LAMP Assembly, For estimate contact any nearest SONY SERVICE CENTRE.
Thanks for using fixya.
Nov 17, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Left rear turn signal bulb is burned out.
Tail Lamp Assembly
Removal & Installation
To Remove:
  1. Open the rear compartment.
  2. If equipped, disconnect the cargo net.
  3. Remove the wingnut and pull back the rear compartment trim panel.
  4. Remove the wingnuts from the tail lamp assembly.
  5. Remove the tail lamp assembly from the rear body panel.
  6. Disconnect the electrical connector from the tail lamp assembly.
  7. Remove the tail lamp socket by turning counterclockwise.
  1. To Install:
  2. Install the tail lamp socket by turning clockwise.
  3. Connect the electrical connector to the tail lamp assembly.
  4. Position the tail lamp assembly to the rear body panel.
  5. Install and secure the wingnuts that attach the tail lamp assembly to the body panel.
  6. Position the rear trim panel to the rear compartment. Install and secure the wingnut.
  7. If equipped, connect the cargo net.
  8. Close the rear compartment.
      Please don't forget to rate !!!!!!
    Mar 28, 2009 | 2002 Buick Century
    How do I replace a taillight lens on a 1991 Geo Storm?
    Rear Turn Signal, Brake and Parking Lights
    STORM COUPE
    1. Disconnect the negative battery cable.
    2. Lift the luggage compartment floor carpet toward the front of the vehicle and remove the spare tire cover panel.
    3. Remove the ten plastic retaining clips from the rear end trim panel.
    4. Disconnect the luggage compartment lamp electrical connector.
    5. Remove the luggage compartment trim panel and the rear end trim panel.
    6. Disconnect the rear combination lamp assembly electrical connector. Fig. 1: Rear Turn Signal, Brake and Parking Lights — Storm
    1. Remove the seven nuts and the rear combination lamp assembly from the vehicle.
    2. Disconnect the rear combination lamp electrical connector.
    3. Remove the four bulb sockets from the rear combination lamp assembly and remove the four bulbs from the sockets. To install:
    4. Install the four bulbs to the sockets and install the four bulb sockets to the rear combination lamp assembly.
    5. Connect the rear combination lamp electrical connector.
    6. Install the rear combination lamp assembly to the vehicle and the seven nuts.
    7. Connect the rear combination lamp assembly electrical connector.
    8. Install the rear end trim panel and the luggage compartment trim panel.
    9. Connect the luggage compartment lamp electrical connector.
    10. Install the ten plastic retaining clips to the rear end trim panel.
    11. Install the spare tire cover panel and the luggage compartment floor carpet.
    12. Connect the negative battery cable.
    Mar 21, 2009 | 1991 Geo Storm
    Lamp Replacement
    take the panel off of the bottom front of the TV - under the screen almost at the floor - with your hands. unscrew the screw on the caution statement and open the panel. you'll see a handle and another screw to the right of it - loosen that screw (it doesn't come all the way out - or shouldn't, anyway). slowly pull the handle until the lamp comes out - if there is busted glass, clear that out. Slide the other lamp inside the television the same way and power back up.
    This should work, however - there are a couple of things to cover:
    -If you ordered the lamp from Panasonic it would have come already in the assembly. If you ordered it elsewhere it may just be the bulb. If that's the case, you will need to assemble it yourself of have someone do it for you. You do not want to get oil or fingerprints on the bulb as this will significantly reduce it's lifespan.
    -You may want to reset the lamp timer in the television once you get the new lamp inserted. First you have to have the television powered on and no messages or menus on-screen from the TV. Then use the original remote and take it to the television, make sure it's in TV mode and aimed at the IR sensor. Then, press and hold VOL- on the TV itself and PIP on the remote at the same time for 5 to 10 seconds. You should get a message that says "lamp time was reset to 0".
    May 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    298 people viewed this question
    jasbo
    jasbo
