Question about Garden
Filled with gas/oil mix and won't start. Was running fine 30mins before. No issues at that time.
    Brigadier General:
  • 4,088 Answers
Remove the spark plug and test for snappy blue spark. If ok, pour a little fuel mix into the plug hole and try for start. If it pops several times, check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines and the primer bulb. Did you make sure that you used proper mixing of the fuel/oil? Be sure to use a modern synthetic saw oil with fresh fuel at the required ratio and use it's own can for mixing/storage. Shake the can thoroughly just before filling the saw. Hope this helps!
Posted on Sep 05, 2010
I filled the gas tank in my chain saw with bar oil. Is there an easy way to remove the oil from the carburetor and get it started?
Dump out the bar oil and put in some pure gas and shake the saw to thin the bar oil. If it has a primer bulb push it a few time to flush the oil through. Dump this out and put in the proper mixed fuel and try starting.
Nov 03, 2013 | Husqvarna Garden
Gas gas trials starts but splutters and loses power
Possibly Washed The Rings Running With No Oil Mix. If Compression Is Less Than 80 P.S.I. It Will Not Run. The Mix Should Be 24 To 1.( 3.5 Ounces Of Oil To 1 Gal. Of Fuel). Hope Its Not Too Late .
Apr 23, 2013 | 1998 Gas Gas EC 250
What causes oil to come out of exhaust. was running fine 3 weeks ago.
ethanol gas for one thing. When it is left to set it breaks down the gasoline. You have a two cyc. engine (gas and oil mix) Clean the plug then take the unit and shake the unit to mix the gas back up. This may not work but its worth a try. Or drain the unit completely use non-ethanol gas make a new batch and replace plug.
Feb 22, 2013 | Troy-Bilt Pony Garden Tiller
My 1994 Jeep Grand Cherokee won't start. It turns over but won't ignite or stay running. It was running fine until I filled up with gas and was driving home. I've tried to reset the security system wi
The gas u put I'm the tank was high octain if it was it was making the engine fire to early replace the gas and it should wor properly
Feb 16, 2013 | Cars & Trucks
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
What octane is best for older outbourd motors
Never had a problem using the lowest octane gas in any outboard motor. Even the old two stroke where gas and oil are mixed, the lowest octane worked fine.
Apr 24, 2012 | Boating
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
Honda gx110 3.5
I'm assuming this is a 4 cycle engine. If yes check the level of the oil in the crankcase - DON'T over fill, drain some out if over filled. If 2 cycle engine your oil mix is to rich. drain gas from tank and mix a fresh match of fuel with the proper amount of oil.
Jun 24, 2009 | Honda 8 HP Engine
Black oil out of ehaust
It is black just due to the carbon from the exhaust and it has been building up from day one. Don't worry about it other than being sure you run premium gas at 32to 1 mix. = 4oz two stroke engine oil per gallon of gas. NEVER use motor oil in the gas.
May 01, 2009 | 2003 Husqvarna CR 125
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
