Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Cub cadet lt1045. 1.Do the valves in front of the engine need to be coordianted a certain way, as far as being loose to the touch, or firmly held in place? Also if I need to adjust them what tool should I use. 2. Before I place a new gasket inbetween the valve cover, do I need to put a bit of oil around the outer rim? Also, will a new one on there stop small amounts of oil from leaking out. Thank you!!!
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
wilsodfarm
  • 986 Answers
SOURCE: Cub Cadet Riding Lawn Mover with Kohler Engine -
you need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Posted on Aug 20, 2010
Testimonial: "Thanks much for very fast response. Don't remember seeing this in manual. Expect this to work. Was puzzling.,"
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
  • 20 Answers
SOURCE: what the air pressure in front tires on a cub
check the side of the tires . it will tell you. szm230
Posted on Apr 15, 2011
  • 3074 Answers
SOURCE: wiring schematics for 2007 cub cadet lt1045 need
this should help Tim:
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
Posted on Jun 04, 2011
Cub cadet just dropped dead?
like a car engine broken rod--piston ring--wrist pin --blown gaskets
May 18, 2017 | Cub Cadet Garden
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
How do I ADUST the valves on my cub cadet rzt zero turn lawn mower???
you will need to take it to shop it is complicated to do
Apr 17, 2014 | Garden
Is there a certain way the blades should be when replacing belt on rzt 54 cub cadet mower
If I understand your question. No, the spindles are not timed. This is if you mean where they go as far as rotation.
Apr 11, 2014 | Cub Cadet 42 And 54 Inch Blade Operator's...
Cub cadet lt 1042
Some of those cadets (like those with the Command 20) have a compression release mechanism on the cam which is intended to make that engine crank easier but disengages once the engine fires up. It's a plastic part and is prone to break, resulting in a lot of strain on the starter motor. Interesting design, bad materials. Sometimes the engine will start anyway but this is not a good idea to operate this way. Pull the valve cover. Look at the motion of the exhaust valve when you turn the engine by hand. It will look similar to the motion of the intake valve if this part is broken. If it's working correctly, you should see the exhaust valve open slightly just after the intake valve closes. I'll attach a video to show what it looks like. Replacing the bad cam is a bit of work but not terrible.
Oct 04, 2013 | Cub Cadet Garden
Cub cudet 31p7770299e1 briggs stratton engine
only thing left is valve seat is loose and poping loose at a certain rpm causing backfire threw carb has to be intake valve
Apr 23, 2013 | Cub Cadet Garden
check and see if intake valve seat is loose as motor gets hotter condition worsens
My son was mowing, with our cub cadet 2166, and ran the left front tire into a fence and now the steering wheel wont work. You can turn it and it feels really loose but it isn't connecting to the
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
May 19, 2012 | Cub Cadet Garden
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
373 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
