Question about Sony Network Walkman NWZ-S545 Digital Media Player
My sony player won't turn off and when i connect it to the computer it will turn back on and the battery doesn't charge. Also i can no longer transfer songs anymore. Please help!
I have a similar problem too. on mine the option button doesnt work which you know operates the on/off switch as well as other important options like timer and alarm. everything else works fine except for that button. i spoke with sony and they said it was an internal error and that my player was under some program where they would take a look at it or something like it. try talking to them to see what you ger
Posted on Oct 28, 2010
I dont have a solution but i have a very similar problem!
Posted on Sep 21, 2010
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
MY SONY WALKMAN CANNOT BE OPENED, IT LIGHTS UP THEN TURNS OFF IMMEDIATELY
What do you mean "MY SONY WALKMAN CANNOT BE OPENED"? If you mean that you can't get to the battery, then you should look at the charging piece in the MP3. If it wiggles or moves in any way, then there is no way to fix it. I myself had that problem once, and it needs charged, but won't take a charge for some reason. I glued the piece in place with super glue which didn't help, and even put a drop of water on it to see if the electricity needed a material to carry it. That didn't work either. I gave up, as there are no screws, so you can't put it back together. I would suggest getting a new one, getting a new charger, or taking it to the store you bought it at. If that doesn't work, then bring it to RadioShack and ask for help. It's worth a try. Or, as I always add at the end, continue looking on the computer.
Jun 16, 2012 | Sony NWZ-E443 Digital Media Player
My player turns on and displays the pearl icon and no longer moves
Hi
Try removing the device's battery.
Leave the player in the frozen state until the battery dies.
Connect the mp3 to a computer and turn the computer on.
Leave it charging for 15minutes an then try playing music while its still charging.
Feb 28, 2012 | Audio Players & Recorders
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
Wont Charge
Yeah, I had this problem too because I was connecting the USB proprietory connector/cable at the front USB drives on the computer. If you have been using front USB connecters, try using the back USB drive connecters.
It worked for me :)
Apr 12, 2009 | Sony NWZ-E436F MP3 Player
Sony Network Walkman NWZ-S545 Digital Media Player Logo
250 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
