Question about JVC LT-42X579 42 in. LCD TV
Hello my TVC LT-47X579 wont come on the blue power light just flashes after a few seconds
  • JVC Master
  • 8,457 Answers
Unplug,replug the tv about hour,the tv should reset itself back to factory setting.The tv should work now,not than the power supply board is dead.That the board,where the power a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 05, 2010
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Power light flashes a few times, but tv wont turn on
The power light is giving you a Flash Code telling you something is wrong. Search under <Manufacturer> <Model> Flash Codes or service manuals to narrow down the issue. Usually it means a "Not user serviceable repair" is about to happen.
Mar 14, 2015 | Televison & Video
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
What is a bonded channel signal
A 'bonded channel' is where the modem combines two or more channels together, for increased bandwidth.
The first light <Power> should be green, indicating power is on.
The second <Receive> light can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for downloading. That is too say, it is bonding(higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The third light <Send> can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for uploading. That is too say, it is bonding, (higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The fourth light <Online> is green, only....
If green and flashing, it is scanning for a connection.....
If green and not flashing, it is finished scanning....
The fifth light is the WiFI indicator of network traffic. (It also is used for WPS pairing, which I doubt you will use. Just stick with the WiFi indicator function...). It should be green, normally..., or non-WPS....
If #2 is blue, and 3# is green, normally...., I suspect that there is too much loss in your in-house system of wiring, and splitters. If that is the case, try putting a 8-12dB 'tap', in series with the whole house. That way, the loss is minimized for your modem to 'send' high bandwidth stuff upstream to the cable guys.... Be sure that the modem is connected to the 'tap' port, the house to the 'out' port, the cable company to the 'in' port of the tap block. I pasted a couple of examples of taps, at the bottom of this, to show the port labels. The tap loss to the rest of the house, is minimal to how well everything else works. I get a +15dB signal from the cable company. But, too many splits, left my modem in low speed upload mode. By-passing the splitters of the house, by adding the tap as only loss to modem uploading, my blue light always stays on. I also added an UPS, to cover power failures, and glitches. That was a well spent $50 special!
a3e73f03-c380-49da-8c63-30f45940ca66.jpg ef068fc8-f053-49ce-a577-d352db809e0b.jpg
Jul 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
JVC LT-47X579 blows fuse WHEN CABLE IS HOOKED UP
Most likely a surge in the cable line! I would call your Cable Provider for assistance.
Apr 22, 2012 | JVC LT-42X579 42 in. LCD TV
My JVC LT-47X579 is not "turning on" since we
hmm i had the same problem the saturday before on my lt-42x579but i didnt have anything hooked up to it blue light came on then flashed ..no pic this happend one week after it was pd off from a rental store we should investigate
Dec 22, 2010 | JVC LT-42X579 42 in. LCD TV
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
Blue light flashes no power or sound then comes on for a second then off again
i listened to a few people and took a shot at the bulb that was the problen i found 1 about 10 miles from my house at 189 witch was a little high but it was done in a few hours, thanks
Apr 18, 2009 | Televison & Video
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
Camera Wont turn on and blue light flashes
The possible answer is that batteries are past thier best now and even a 'full' charge is not delivering enough power. treat your self to new batteries.
Aug 13, 2007 | HP Photosmart M425 Digital Camera
JVC LT-42X579 42 in. LCD TV Logo
860 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
