posted by Yani06 on May 12, 2008
My TV won't turn on. The green light turns on three times, but no picture comes on and the green power light goes out altogether. How do I fix it?
1 Other User Has The Same Problem
Comment by jennimes, posted on May 14, 2008
my set started out only shutting off and restarting once, the picture would be fuzzy for just a few minutes then clear up and be fine. today it wont turn on at all. another thing is when its shut down at night some people in my house hold dont realize that they only shut down the cable not the tv so very often the tv has been on all night. does this help to pinpoint that something has most likely burnt up?
Solution #1
posted on May 12, 2008
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for RCA D52W20 52 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
RCA D52W20 52 in. Rear Projection HDTV-Ready...
green light flashes
green light flashes
tv worked fine when shut off... Answer This...
damn tv
damn tv
there was a post up top that... Answer This...
SOUND
SOUND
it worked ok a few hours ago,... Answer This...
Convergence off on Digital...
I have a RCA D52W20 52 in. Rear... Answer This...
power light flashing????
flashes 9, then pause and 5.... Answer This...
Repair Service
Find Projection TV Repairman Near You:
Find Parts
