Question about Video Cameras
Where to fix a Sony camcorder
I've a sony camcorder 3 years old hardly used but all of a sudden its LCD and eyepiece don't display the picture, some time lines do appear. I need to fix this camera. Anyone please let me know where in Ottawa, i can get this done.
Thanks
Jay
Did you find a repair place? I am in the same situation, with the same problem, in Ottawa. If you did get it fixed, how much did it cost?
Posted on Nov 02, 2008
IN SONY HANDY CAM HDD XR150 - LCD SCREEN THE SOME COLOR LINES ARE DISPLAYING INSTEAD OF PICTURE . THE PROBLEM OCCURRED AFTER REMOVING THE HANDY CAM FROM THE TV SET AS PLACED IT OVER 30MIN.
You need a new sony display flex cable installed in your camera.. it is a rather simple procedure.. dont let anyone tell you it is going to cost 300-500.00 to fix. the cable or flex that makes the display viewable is called a LCD display Flex. If you don't get any image on your display, the image has lines, display has no backlight or anything like that, replacing this flex cable should fix the problem.
you can buy the flex cable on ebay for less than 30.00 and the fix is rather simple.. the display has the flex cable on the back side and there are 3 screws that holds the display on the camera body. when you take them out of the camera using a PH00 small screw driver, you can then take the flex cable out of the display and easily replace.. it doesnt take rocket science to take these out and replace them.. good luck.. remember... you can buy the flex cable that makes the display viewable and then when it is replaced you will then be back in business with your camera.. good day....David...Mt Holly, NC
Jul 29, 2011 | Sony Handycam DCR-SR300 Camcorder
Sony TVR68 camcorder--Playback mode works fine. In camera mode, I have no image in eyepiece or LCD screen
Hi obx4ever, If this helps, the CCD was a problem I had in a lot of those camcorders and only replacement cured the problem. Only a sony authorized service centre will be able to replace the CCD for you. The CCD is a closed coupled device which generates the image that you see in the eyepiece and LCD screen when in picture mode. Michael.
Aug 24, 2010 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam DCR-HC42 Mini DV Digital Camcorder LCD goes black purchase 4 year back. Any chance to repair LCD.
If you are able to see picture in the viewfinder (eyepiece) on closing the LCD, then the cable connecting the LCD to rest of the camera has gone bad and needs replacement. Take it to a Sony service centre. They will charge Rs 750 for service charges and about Rs 700 for the cable. You can save the service charges if you replace it yourself, but I'll advise against it unless you are conversant with these sort of precision jobs.
Nov 01, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony MiniDV DSR-PD170 won't playback recorded video
the tape path of the camera needs to be adjusted ,so you need to get that fixed.
regards
Aug 04, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Making a buzzing sound, and displaying horizontal lines
Contact Sony and tell them the problem. As long has youve had the playstation3 for under one year and have not touched the warranty seal at the side of the playstation then you can have your old playstation3 replaced.
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
SONY DCR-SR300 with CMOS viewfinder
I suddenly had similar problems with my SR300. I replaced the flat ribbon cable (looks orange) between the body and the LCD display and camera works like new. The ribbon cable is subject to cracking the internal wires where it flexes when you open and close the LCD display. There was also a new part number for the cable so I suspect it is a known problem.
Sep 02, 2008 | Sony Handycam DCR-SR300 Camcorder
My Sony DSC H-2 camera LCD display
Does the finder LCD work ? Push the button directly to the right of the eyepiece to toggle between the large panel LCD and the finder and PLAY a recorded pic. If it will display a recorded pic but not display a live pic, the shutter blades are stuck together. It'll have to go to repair - about a $105 repair.
Jul 26, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Won't record picture
it probably is the ccd imager. call sony and tell them about the problem. since they had a recall for this issue the may fix it for free.
Jun 11, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Red vertical smears on LCD display and on playback
Your camcorder is on a list with potentially defect CCD light sensors. Sony is replacing them free of charge. Go here for the link and free mailing label: http://www.imaging-resource.com/badccds.html
Dec 13, 2006 | Sony Handycam DCR-VX2100 Mini DV Digital...
Video Cameras Logo
117 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
