Question about Kitchen Ranges
MY ELEMENTS ONLY WORK SOMETIMES I HAVE TO BANG THEM TO WORK THEY SHUT OFF ON THERE OWN
  • Kitchen Ranges Master
  • 43,501 Answers
Here is a tip that will help you figure out why your oven will not shut off...
Electric Oven Problem Oven will not shut off
heatman101
Posted on Sep 07, 2010
My electolux superba convection oven is not maintaining it's temperatures?
Heating elements cold be going bad look at them with a flashlight if either of the elements look thinner than the rest of it then it needs replacing before it goes out completely. With aloud bang a bright arc flash and smoke. Very scary. There's a metal tag on the inside of the oven door jam.write the model and serial number down. Shut off the circuit breaker for the stove should be a 50 amp double breaker. Remove 2 small 1/4 inch screws. Slide the element out straight to you. Remove the 2 wires with the same 1/4 inch nut driver keeping the wires separated .Do Not turn on the circuit breaker till the new elements are installed! !! Use the model and serial number to get your new elements first.
Sep 26, 2014 | Ovens
Ge oven will not turn off after replacing element
If the element stays on even when the control is shut off it is most likely that the contacts are welded together in the control. This usually happens when the element blows out with a big bang. If this is the case the control will need replacing.
Feb 16, 2014 | Ovens
Kenmore elite dishwaher 1646 not cleaning dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
Banging noise when motor turns off
Have you replaced your air filter recently? Often this is a symptom of a restricted return. The blower almost causes a vacuum in the duct work, and when the system shuts down the duct "pop" back out, causing this banging noise. Hope this helps
Feb 05, 2010 | Honeywell Electronic Programmable...
Oven not working
It sounds like the element/s have blown, especially if the fan is still working o/k.
You cannot always tell by looking at them if they are faulty or not.
Only way to be sure is to test them with a meter.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Frigidaire Ovens
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
SA-AK57 BANG!! F61 error
The primary amplifier ic is on it's way out.
you will need to replace that and the regulators for it too.
Feb 17, 2008 | Audio Players & Recorders
Water drip into washer, used to gush in. Now water pipes bang, whine
The problem is the 10 cent rubber washer in a shut off valve in your plumbing. The brass screw that holds this washer has corroded and the washer has come loose. It now floats around inside the valve and the water flow can be blocked at one time, whistle, howel and make bangs at another. It could be any valve including the main shut off. You can listen to the pipes but the sound travels, so you are looking for the loudest spot. A new washer and screw could fix it, but sometimes the screw is broken off requiring a new valve stem. Be prepared to replace the whole valve.
Oct 31, 2007 | Maytag Washing Machines
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
