Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Have a whirlpool duet steam washer. when you start a cycle, water goes in for a short time, then it indicates "suds." It drains water then message changes to "F35" and the drain gets stuck running. I have unplugged washer, tried to run clean cycle, checked drain underneath, and nothing helps. suggestions?
  • tomjsobie Sep 10, 2010
    Thank you! After blowing through the tube to no avail, I ordered the pressure switch and installed it. It worked!
  • 10,515 Answers
Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after doing this, you will likely need to replace the pressure switch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 05, 2010
  • 1borneachday Sep 15, 2010
    So I guess I have a BIG problem if I have the washer/dryer stacked in an enclosed closet. Hubby can definitely fix this but has a BAD back and they just about ripped out the door jams getting these puppies installed. If we can get the dryer out, then we just have to remove the top or would we have to pull the washer too? Maybe it can be tipped forward to get the top panel off?
I have a whirlpool duet steam washer model number wfw9500c01 keep getting suds code on display. I clean washer every month with refresh tablets or as indicated. what do i need to do to resolve this?
the suds code is telling you that you're using to much detergent,you should be using H.E. detergent and like 1/4 cup full of it.if you use more than that it can oversuds and this is the number one cause of damaging the spider gear.if the spider gear goes you'll be in the market for a new washer,you'll know if it goes when in spin the machine will bang loudly,you can run the washer with just water,let it run for a bit and drain it to get the extra suds out,while it's agitating look in the machine most likely you'll see the detergent in the water.
Apr 17, 2011 | Whirlpool Washing Machines
Tip
Whirlpool duet washer F02 or F21 error code.
This error code indicates that drain times are longer than expected.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Temporary fixes:
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
on Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A WHIRLPOOL DUET STEAM MODEL WFW 9600 TAOO. NO WASH CYCLES WILL START. I GET A FLASHING 'SUD' AND THEN CODE F 35. DO YOU KNOW WHAT THE PROBLEM IS? WHAT PART NUMBER DO I NEED? WHERE CAN I FIND IT?...
SUD, usually caused by using the wrong type of soap. Your soap should have the letters "HE" on front of box/bottle. SUD can also be a bad drain pump, question is, does it still have water showing in tub?
F35, is a pressure sensor # W10156252, good luck finding it, as Whirlpool has problem keeping these things in stock. They list price at $112.82. Only takes about 20 minutes to change. Research sears.com, select PARTS Direct, enter model number, click on cabinet parts, find analog pressuer switch, see if they have in stock. Or, research the net for someone that does.
Take top of washer lid off, pressure switch is located on top right rear side wall of machine.
Good luck.
Oct 01, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code
Our new Whirlpool Duet had the same problem after only three months of use. We contacted Whirlpool since the washer is still under warranty. The issue is a "bad pressure switch". The part number is W10156252. Service company replaced the part yesterday, and the washer is working like normal. Whirlpool nor the service company had any explanation why the part would go bad in such a short time. No charge since the washer is under warranty.
WARNING - There must be a shortageWe were initially told that the part was backordered for 2 to 3 weeks. We even tried to obtain the part through other vendors and got the same time frame. Furious with the potential of being without a brand new washer for 3 weeks, we spent many hours on the phone with Whirlpool trying to expedite the part. After some strong encouragement and moving the issue up the chain of customer service, Whirlpool agreed to pull a part from the factory inventory where the washers are built. The only problem is that nobody could tell us when, or if, the new part would be shipped. Suddenly, the part just arrived by FedEx at our house. In all, our washer was inoperable for 1 week. Be persistent. They will tell you over and over there is nothing they can do.
If you negotiate well, Whirlpool will extend your factory warranty for an additional year.
Feb 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not do anything
You need to drain the machine manually. Drop the drain hose to a level that is lower than the drain pump and the water will syphon out. Once all the water is out you can open the door. Remove the washing and then close the door and start a rinse cycle. While the machine is taking water, open the dispenser and pour half a cup of milk in with the water. This will neutralise the suds. Once all the suds are gone the washer will be ok.
Oct 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
373 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
