Question about Maytag Neptune MDE5500AY Electric Dryer
We just bought the dryer, and the clothers are not drying. I have 2 sheets, 2 pillowcases and they have been drying for 2 hours and are still wet.
  • Maytag Master
  • 3,053 Answers
Hello, starre I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
My Maytag dryer is 2 1/2 years old. I believe the belt is broken on my dryer. My gas dryer heats up and the drum turns, however,it takes a long time to dry my clother. Would this be the belt and is...
2 years parts and 1 year labor. Warranty work usually requires a sales receipt.
The only way that the belt would affect the dry time is if it is very loose.
First look for a clog anywhere from the filter to the dryer vent cap outside. The dryer vent hose should be clean (very little lint present). Any obstruction like a kink in flexible vent line (which shouldn't be used) will slow things down.
If it's none of these things, the thermostat or gas valve may be bad.
Jan 07, 2011 | Maytag MDG2706A Gas Dryer
Looks like either an accumaltion of lint or dryer material behind holes in drum inside. seems like clothers are absorbing an odor.
Unplug machine, remove cover and clean with a wet/dry vac, also clean vent line from dryer.
Oct 03, 2010 | Dryers
Hours for towels or sheets to dry
a dryer can only handel so much if you over load it it cant tumbel the load inside of it so the warm air wont dry them out,,,also what is it set on??? low or hight heat?? how wet are the sheets when you put them in the dryer??? is the dryer getting a good air flow,, it need to breath in lots of air,,,,and that hot wet air need to get out freely,,,if its even slightle blocked the dryer cant work well,,,how often do you clean out the dust filter in the dryer,,,(this should be cleaned every time you use it) also if the sheets just tiy them selfs into a big knot they wont dry
i hope this was of help to you
Jun 27, 2010 | Asko T712 Electric Dryer
My Hirundo is not drying well. After hours of spinning the clothers are still wet, and not like usual. The water is draining. Is there a heat elementy to replace? A vent to clear?
Make sure all vents are clean and clear. Next, check the thermal fuse. It should be located just inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested by using a multimeter or ohmmeter to test for continuity. A lack of continuity indicates a blown thermal fuse.
Another cause could be a faulty heating element. It can be tested in the same manner as the thermal fuse. Hope this helped and best wishes.
Aug 14, 2009 | Equator EZ 3612 CEE Front Load...
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Takes almost 4 hours/timed cycles to dry 1 load of bedding/sheets
most of the time your complaint is the home owners house venting.run a load with the venting detached[it wont hurt a thing] if ok then must clean venting till dried as well as with out venting.if still long dry times first must make sure air ways in dryer are clean[should have good air flow at back if hand held there] and may need to remove front to clean lint filter area.and inspect blower ,making sure mounted to shaft and not worn in the center[blower key way, inside the hole where motor shaft goes thru blower]you dryer only has one element so if you have heat its heating.if you did all above and have problem still can be electronic[thermostats,timers etc........but i have fixed 1000s of dryers and their having problems are rarer.i hope that helps God bless ,tom
Jan 08, 2009 | Maytag Dryers
Twisted sheets
dry your sheets separately.
Oct 28, 2008 | Kenmore Elite HE4 Electric Dryer
Sheets wind together in a damp ball
I have a different model Bosch dryer, but I have the same problem.
I've found that the flat sheets dry okay if you have them in with other things (like pillowcases and t-shirts). I learned long ago though that you can't put those things in with deep fitted sheets; the little stuff winds up caught in the corners in damp wrinkly wads.
So I dry the fitted sheet separately, and throw in a couple of clean tennis balls. They're noisy, but harmless, and they keep the sheet from balling up.
Oct 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
14 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
