Question about Kenmore 24032\24036 Top Load Washer
Washer leaking oil - Kenmore 24032\24036 Top Load Washer
  • 30 Answers
If the oil is leaking at the top of the tub, around the agitator, you will need to dig out and repair the brake and drive tube. If it is leaking at the bottom of the washer, about a quart, you will need to replace the gearbox.
Posted on Jun 13, 2011
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
Oil leaking from within body of washer after half hours use and after switching off.. Oil is clean.
This is noticed on the Karcher washer and does not need any attention unless you are having a large spill over or leak. The oil oozes out when the pressure washer works for some time and is a result of a pressure leak when the washer is used for sometime.
I had seen this happen on mine for sometime , checked on all sides for any damage but there was none. So ignored but cleaned off the leak and was not seen then.
Mar 30, 2011 | Karcher Pressure Washer Gun 91120200...
Kenmore heavy duty washer leak oil out while putting belt on where do I put oil in at and what kind of oil
It sounds like your tansmission seal is leaking. I don't know of any washer you put oil in.
Jan 06, 2010 | Kenmore 23822 Top Load Washer
Kenmore washer. leaking brown oil like substance
Oil leak can be bad, can be gearbox on top loaders / or bearing fault..
Oct 01, 2009 | Washing Machines
Pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Jun 22, 2009 | Karcher 2500 PSI Pressure Washer
Flipped Kenmore over to replace pump now oil leaked out, where?
did you tip the washer all the way over? bad idea if you did. is the washer functioning ok? if so don't worry about it. but no....you cannot put the oil back in. It might be ok as long as it does not leak any more oil. This oil is comeing from your transmission. which controls your agetation and spin.
Mar 26, 2009 | Kenmore 22642 Top Load Washer
Oil leaked into the washing machine tub.
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Jun 17, 2008 | GE WBSR3140DW Top Load Washer
Karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Kenmore 24032\24036 Top Load Washer Logo
176 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
