Question about Maytag Atlantis MAV6000 Top Load Washer
The final spin sometimes does not happen and I have to put it on spin cycle again to have the water drain and the spin to begin.
    President:
  • 3,773 Answers
Timer is going out . Getting loose and losing connection.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 05, 2010
Kenmore 80 series has loud banging sound during the spin cycle
I had a washer that at the beginning of the spin cycle it was fine, but when the water was half drained it would begin making a banging noise. When the draining reach the bottom and the spin speed increased it was fine. Finally found the problem - What happened was the tabs that hold the control arms for the brake had loosened. During the spin cycle especially in the middle of the cycle (when torque was at the maximum and speed was at medium. The brake spring would flex out due to compression and hit the some extended metal tab on the brake housing. Once the speed increased and the torque reduced the spring no longer hit the housing tabs. Fix the problem by bending the tabs that hold the brake control arms in place to better hold the control arms in the proper location.
Jan 19, 2010 | Kenmore Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Washing machine stops after final rinse cycle
Your lid switch is bad. It must be replaced.
Jun 26, 2009 | Whirlpool Washing Machines
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
Help Guru Please
Ill try,
first off its normal for water to spray in during the final spin( its a spray rinse), as far as the water coming back into your machine after the final spin stops, you have an issue with oyour drain, i would assume that the drain hose is NOT going into a stand pipe"open drain", but instead clamped to another hose leading outside or to a drywell, in which case youll need to install a "one way check valve". whats happening is after the final spin is done al;l the waterin the drain line is reurning back formn the drain hose.Proper insstallation will cure this.
lastly its hard to describe"slower than usual spin" it will progressivly spin faster as moire water is removed form the machine, i wqould rectify the drain issue before i concern my self with this( and make sure you not selecting a :gentle spin" option of coarse... hope this is helpful to you!
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Waher Top Load
It is normal to have some water in the wash tub when the spin cycle starts. It will gradually drain down as the tub begins to spin faster. However, if you STILL have an abnormal amount of water in the tub as it begins the high speed final spin, you may have a slow drain problem with your plumbing, or something restricting the water in your drain pump. If you've never had drain problems before, I would suspect you might need to check your pump. I'm posting the following link that explains how to replace the pump, because it explains how to access and remove it:
http://www.fixya.com/support/r397092-replacing_water_pump
These pumps are NOT serviceable and are sealed. Do not attempt to disassemble it. You can, however look inside the pump to see if anything is lodged in it. Underwire bra hoops, socks and underwear are common items that are found. Another thing to inpsect is the back of the pump where it mounts to the Drive Motor shaft. The hole in the pump should have two flat sides. Sometimes, this hole rounds out and the pump begins to free spin on the motor shaft. Let me know if you require additional assistance. I hope this information helps you.
NOTE: If you require a replacement pump, they can be ordered ar searspartdirect.com or replairclinic.com. Make sure you have your COMPLETE model number handy.
Aug 30, 2008 | Kenmore 24042 Top Load Washer
Having issues with my washer Model # LSR7010PQ0. Will not perform final spin cycle. All the water is draining.. basket just wont spin. Tried the spin cycle on one of the other settings and that worked. ...
As the machine goes through the cycle, it should do what is called a neautral drain (drains water without the tub spinning) then a momentary power intreupt allows the gear to slip down and the spin begins. If this is not occouring on one cycle, it is usually a bad timer.
Jun 13, 2008 | Whirlpool Washing Machines
Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Jul 24, 2007 | Admiral AW22 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
