Question about Protron Televison & Video
Hi... i have no power getting to my t.v. The cords are all connected and the power source is good.
  • bryce_raff Sep 05, 2010
    The t.v. is a protron PLtv-3250
  • 10,594 Answers
I need model number and brand info of your tv to diagnose possible cause of no power problem.
Thanks.
Posted on Sep 05, 2010
  • Shahid Electronics
    Shahid Electronics Sep 05, 2010
    OK, its Protron PLTV-3250
    Does power indicator lit when tv plugged in?
    If not then power supply board seems defective and need to be replaced.
    Let me know if you have additional question.
    Thanks.
The circuit board where the battery plugs in not making a good connection and gps wont come, the wiring from car lighter to gps is good , canyou solder wiring to power circuit board.
Hi, yes it's possible you need a soldering iron and 60/40 rosin core solder, remember that soldering iron can make serious burns so be careful, and always work with the device disconnected from any power source.
Nov 13, 2015 | Magellan Car Charger Vehicle Power Adapter...
No power
If it is not getting any power at all, only one of three things: cord is fried/dead; could be the outlet, try something else in the same socket; or, the board in the printer is dead.
1. Press the POWER button to power on the printer The device has a <POWER> button.
Connect the power cord from the printer to the electrical source.
Press the <POWER> button.
Wait until the device has completed its cycling process before submitting a print request or completing installation.
2. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
3. Disconnect and reconnect the electrical cord to ensure a secure connection 4. The iP6000D may require repair
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
5. Try a different electrical source / outlet
this will surely fix your problem..
Dec 06, 2007 | Canon Pixma iP6000D InkJet Photo Printer
I HAVE A JVC HOME THEATER SYSTEM MODEL NUMBER TH-C5 THAT THE RECEIVER POWERS UP BUT THE SUB WILL NOT AND THE SPEAKERS ARE NOT WORKING.
Page 42:
No sound. The system cord and/or speaker cord is not connected. Check the connection.
The audio cord is not connected to AUDIO IN (VCR)
and/or DIGITAL IN (DBS) correctly.
Connect the cord correctly. (A pg. 13)
An incorrect source has been selected. Select the correct source. (Apg. 17)
The decode mode is not set correctly. Select the proper decode mode. (A pg. 35)
http://www.retrevo.com/support/JVC-TH-C5J-Home-Theater-Systems-manual/id/318ag518/t/2/
Do you think the powered subwoofer itself might have a power problem? Check its cord.
Dec 26, 2010 | JVC THC5 Home Theater System with 5-Disc...
Will not start. No lights, no noise, no movement.
Hi! make sure that the printer is plugged into a working power source. If the power source is good then try checking the power cable of the printer, if you can use a similar power cable please do so for you to determine if its just a power cord issue. Hope this helps, have a good one!
Apr 04, 2010 | Canon Pixma iP4500 InkJet Printer
No power on sony vpl-cx10 projector
check your power source, power cord... if your power source & your power cord is good, your power supply board is defective.
Oct 29, 2009 | Sony VPL CX10 Multimedia Projector
Mag Innovision LT982s 19 inch flat screen monitor
Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Televison & Video Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
