Question about Fantom Vacums FC251 Canister Vacuum
Ware can i get bags for my vacum - Fantom Vacums FC251 Canister Vacuum
  • 694 Answers
This model vacuum does not use bags. So, you can't.
Posted on Sep 05, 2010
Where is the filter on a Hoover30010 ?
the dirt bag it self is a filter allowing the air/dirt to be pulled into the bag and only the clean air is passed on to the vacume motor !
Nov 19, 2015 | Hoover UH30010COM Bagged Vacuum
Where do you hook up hose
Years ago I used to sell and demo kirbys up to the G-5 model,I believe you have to sit in front of your vacume,raise the wheels as high as they can go and on the logo face tun the crank one way,this loosens the belt and give a little tug and the roller sucking chamber will drop.Pull the chamber away.,now take your hose and stick it over the shaft and lock it down with the wing nut and then you can use all your vacume attachments.UNLESS YOUR TALKING - vacume bag hose- this is just a simple twist and click on the vacume exhaust chamber. Now if your hose is unhooked in your vacume bag it self,you will have to get a new bag attachment or get a repair man to look at it.
Jan 08, 2012 | Kirby G6 Bagged Upright Vacuum
My vacum e2000 electrolux dont start after i changed the bag ?
Try putting the bag in again. There is a kill switch on your door usually in the bottom left as your putting the bag in. Make sure that your bag covers that kill switch and your vac should start again.
Good luck.
Nov 07, 2010 | Electrolux UltraLux 2000 Bagged Canister...
How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Dec 30, 2009 | Dirt Devil Vacuums
I recently put a new bag in my kirby and now when i turn it on, it will not pick up anything
see if you connected it or install it correctly, see if there is any leackage of air, see if it is air tight, the reason is that the air cannot vacum because there might be some open connection between the bag and the air exhaust of the vacum
Nov 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacum bags
The vacuum that you have is over 10 years old. You can no longer get the bags directly from Bissell but if you call a authorized service center near you, they may still have bags that will fit your vac. So the answer to your question is yes....they use bags. Good luck!
Aug 03, 2009 | Bissell 3065 Power Partner Vacuum
I neen parts for a wap vacum cleaner and bags
Here's an amazing thing about FixYa... help via the UK!
Go to www.transplant.co.za and have a look on their "Contact Us" page.  You will find an email address and also two South Africa phone numbers.  They are Wap/Alto agents and will undoubtedly be able to help.
Helpful?  I value your feedback, so please rate me!
Apr 20, 2009 | Vacuums
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Fantom Vacums FC251 Canister Vacuum Logo
21 people viewed this question
Top Fantom Vacums Vacuums Experts
woodzowl307
ray gallant
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
