Copies from my xerox cx865 have dark areas-it is a series of three "bars, running the short length of the paper, though they are darker on one side. this happens even if i just try making a copy of a blank piece of paper. The copies are better if i set the copier to light instead of using auto exposure. i am wondering if it is a corotron wire issue or another setting. in looking inside copier i dont see a physical wire where the corotron wire should be-is it literally a wire strung across the bottom? if so were do i get a replacement wire and how does it get installed
  • baerjc Sep 06, 2010
    i need a more specific solution
  • baerjc Sep 18, 2010
    if that is in fact the cause then i need to know where the magnetic roller is, where i get a replacment (if possible) and most importantly how i replace it. thank you
  • 787 Answers
You need to change the magnetic roller. That's what's causing your problems.
Posted on Sep 06, 2010
  • 666 Answers
Ok well for starters you would normally want to post this under our printers/copiers section in order to have the proper people look at it but your in luck i think i know exactly what your problem is and a simple cleaning of the printer and ink cartridges should fix it this is a link to a very standard copier cleaning procedure which normally will fix any issues with uneven printing
http://www.ehow.com/how_4552926_clean-copier-machine.html
hope this helps
Robb
Posted on Sep 05, 2010
Page has a dark bar along the length of the page copied and it gets darker the more copies you do
Defective toner cartridge. Try sliding out the cartridge, turn it over and slide open the cover/gate that covers the drum. The drum should be clean all the way across. If you see a toner band or anything that would be your proof. 9 times out of 10 this is going to be a bad toner cartridge.
Oct 09, 2010 | Canon PC-430 Color Copier
Xc830 copying dark ,down center of page
There are a series of mirrors on the carriage that moves back and forth under the original glass. When dust builds up on these mirrors it makes the copies darker. Since the dust is blown by the optics cooling fan it does not collect evenly which causes areas of the copy to be darker than the others. On this machine you just have to remove the original guide plate which is the plate with 4 screws in it and has the document size numbers on it. Once that is removed the glass can be lifted out. With the power turned off just gently pull out the scanner bar. The part that initially comes out has 1 mirror as well as a silver reflecting strip on it. Clean both. Now the assembly that follows the first assembly out has 2 mirrors on it. 1 facing downward and 1 facing upward. Clean these 2 mirrors. Re-nstall the glass and plate. Turn the machine on and let the scanner unit home itself. Once warmed up make a copy to test. Cleaning these surfaces will usually correct the problem. There are 2 more mirrors under the black box under the glass but those do not get as dirty and they are harder to get to.
Good Luck and Thank You for using Fixya.
Sep 08, 2010 | Xerox 8830 Copier
Poor copy quality
The drum, developer and other parts have a certain life that they are good for. After they go beyond that cycle they can start to run dirty, use alot more toner, basically give you problems until a complete maintenance is done. The drum can have permanent light fatigue, even though they look good and in alot of cases one side will start to get darker than the other. You should get an estimate of what it'll cost to have servicing done and compare that with the cost of a new or refurbed machine. If the copier is very old, it might be worth it to get a new one. Good luck, please rate this if it helped you. Thanks
Jul 02, 2009 | Xerox Office Equipment & Supplies
Dark streaks on copies from Xerox XC356 copier. Streaks were light at first; changed to a new toner cartridge and streaks are same size/same place on the page -- but now darker. There are three streaks,...
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Mar 04, 2009 | Xerox XC356 Copier
Xerox Copycentre C123 Creating a Ghost Image
First place an original on glass and make a copy -- mark #1. With that same original on the glass, move the exposure all the way light and make a copy -- mark #2. Again with the same original on the glass, move the exposure all the way dark and make a copy --- mark #3. Place #1 in the middle so the the copies read --- #2, #1, #3. The #2 should be the lightest and #3 being the darkest. If #2 is darker than #3 you have a developer problem and you need to call for service. If #1 and #2 are bad and #3 is a good copy your machine probably just needs a good cleaning, mainly the optics and charge units. If all 3 copies are still poor with the speckles, your are looking at the PCU ( photo conductive unit) also called the drum unit. You can order this unit online -- it is a customer replaceable item.
Jan 04, 2009 | Xerox CopyCentre C123 Black and White...
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
