Question about Hotpoint VBXR1090D Top Load Washer
Maytag top loader HE: coin under impeller(agitator). how to remove agitator?
    President:
  • 3,773 Answers
Take a water hose and blow it out.
G.e. Agitators normally need a special puller to remove tub
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 05, 2010
My Maytag washer ripped my clothes. They have holes in them, What could be the cause
If it is a top loader it is the clothes getting pinched at the base of the agitator. Undo the knob on top or the bolt under the fabric conditioner container, lift off the agitator, check underneath, and replace it, making sure it is seated well
If it is a front loader, I had the same problem and it needed a new drum. The ridges around the drum had some sharp bits that were cutting and tearing the clothes as the clothes were sliding over them.
Nov 14, 2016 | Maytag Washing Machines
Top loader. Why are there grinding noises underneath during agitation?
probably foreign objects like buttons, bra wires, coins and anything else left in pockets
remove the agitator and clean out
Jan 23, 2016 | Maytag Washing Machines
My GE Spacemaker wslp1100 top loader is draining very slow causing error code dr. I took black drainage hose off and it seems to be clean. Filters are clean inside washer. I want to know if a coin could be...
You don't reveal full model number. It's not likely that a coin is blocking the water. The pump (part of the motor assembly) may be partially blocked inside or a garment (sock, u-shirt, etc.) may be blocking the water inlet to the pump. It's too early to remove the agitator.
Nov 22, 2013 | GE Spacemaker WSLP1100D Top Load Washer
I have a Maytag Neptune TL washer that won't drain. I took the front panel off and detached the hose from the pump and there were several coins in there. I removed the coins, reattached everything and...
For the FAV6800A or FAV9800A tumbler removal.
The Service manual has the procedure starting on page 37 for the tumbler removal.
It’s not difficult to remove the manual doesn’t call out the Torx driver size required for tumbler removal. You will need a number 20 Torx driver to remove the Torx screw for tumbler removal. I would get a long Number 20 Torx driver for this. See page 37 of the Service Manual for tumbler removal. Looks worse than it is.
The Service Manual for reference. Sears Parts Direct for reference.
When I did a recent Outer Tub Bearing replacement I found $1.78 in coins after removing the wash basket. Gotta check those pockets....:)
I have a post around somewhere of my diy Sump Screen I put in my FAV6800AW to protect the drain pump impeller from coins and other stuff from breaking the impeller or causing clogs. I'll look for the post or repost the pic's.........D*ick
Sep 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How do i remove the loose change trapped under the agitator ?
you'll need to remove the agitator to do that usually. fairly easy to do. the centre piece at the top unscrews (very often it will require you turning it the opposite way you would normally untighten something) remove that then lift it up. there is one other way but you need to be very lucky. some coins will react to a magnet. you may be able to get them out that way tho the whole basin is metal so not as likely.
Apr 24, 2010 | Maytag Bravos MTW6600T Top Load Washer
How do you get the coins out of my MAH8700AWM front loader?
hi there you should remove the agitator first before you get your coin on your washing machine
Jun 13, 2009 | Maytag MAH8700AWM Neptune Front Load...
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
156 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
