Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Glasses won't get clean - Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
  • Viking Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 07, 2010
How do I take off the outer glass on oven door on a frigidaire oven model FEFL74ASG
Good Afternoon clynns108 - Thank you for your question. Here are some generics steps to help you remove the door to your range or you may reach out to a professional directly to further assist you:
Tools needed: Phillips head screwdriver or small quad bit driver.
CAUTION: Edges of door may pose a cut hazard, use gloves or heavy cloth when grabbing edges.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
Jun 26, 2013 | Frigidaire Ovens
My Krylon Looking Glass spray comes off with water after I sprayed the outside of a vase, can I use a varathane to seal it so it won't? it was very expensive spray and says durable but it's not!
Glass is very hard to paint. If you are sure that it is clean and has no grease on it, you may want to use fine grit sand paper to rough the surface of the glass
Apr 26, 2013 | Cars & Trucks
Rings won't come out around glass cooktop
I have had pretty good success with the green scratch pads
Mar 09, 2013 | Whirlpool Kitchen Ranges
Water won't drain out
Hello Veronica Spellman - Have you recently cleaned the filter? This can be doing by a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, pits, etc. You should simply be able to grasp handle, lift out, empty and place it back. Also is the unit making a grinding noise? If so, I personally recommend consulting a professional to move forward accurately and assist with the repairs. The dishwasher could possibly have a faulty drain motor/pump.
Feb 24, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Turned it off,Took out glass shelves to clean, now shelves won't slide back in!!
sounds like liner has expanded because it warmed up try turning it back on let it run overnight and try again
Nov 03, 2012 | U-Line 1175BEV Beverage Cooler
5010C scanner won't skip blank pages
We had this problem and discovered it was caused by a small piece on the glass. Once the glass was cleaned, the blank pages were skipped.
Sep 11, 2012 | Canon DR-5010C Scanner
1986 LeSharo Winnebago (renault 4 cyclinder engine)
I have a 1989 LeSharo & the fuel filter on it is mounted on the frame under the driver's seat, just back of the left front wheel. Hope this helps. I am in need of advise on why mine won't start. Has always started/ No problems til now. Have new battery, fuel filer & plugs.Tries to start, but won't. Cleaned the distributer cap, new gas, even "tune up in a bottle". No progress. Help appreciated!!! Thanks!!
Aug 01, 2012 | Moeller InLine Fuel Filters Replacement...
Door won't close
Have you checked why this is? If you clean all around the door and the glass as well and try to close the door again. If no luck take a look at the manual or ManualsOnline.com. Then you are bound to succeed.
kolbrun
Feb 25, 2012 | Miele Dishwashers
Just moved into this house, with a warnock hersey gas fire wh3990 removed the glass for cleaning now it won't come on .I think I disturbed the log placement ,it has a temperature control but even...
When you replaced the glass, you may have not made contact with the glass safety removal switch. In which case, other than the pilot, nothing else will work. When you cleaned the glass, I hope you didn't use a commercial glass cleaner. As they have ammonia in them and it leaves an invisible residue on the glass. When it heats up the residue will turn white and stay on the interior of the glass. If you did use a commercial glass cleaner, remove the glass (which you're going to have to do anyway) and clean it with a 50/50 solution of vinegar and water. Then dry the glass thoroughly with paper towels.
The glass safety removal switch is generally at the bottom of the firebox opening right under the glass, In fact the glass will rest on it. Once everything is cleaned (if necessary) and reassembled. Be sure that after the pilot is lit, the gas control knob is turned to ON. If you have a wall switch that tunrs the burner ON & Off, it will now take over.
Hope this helps you and thanks for choosing FixYa.
Sep 21, 2011 | Heating & Cooling
How do you change the lightbulb inside the oven??? I cannot get the cover off!
AROUND THE COVER THERE IS A CARBON BUILD UP CLEAN WITH OVEN CLEANER AND YOU SHOULD SEE THE SMALL SCREW HOLDING THE COVER IN REMOVE IT AND GENTLY PRISE IT OFF ..
Nov 22, 2009 | Kitchen Ranges
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
55 people viewed this question
Top Viking Dishwashers Experts
Mike
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
