Question about Soehnle Linea Quattrotronic Digital Bathroom Scale
Soehnle bathroom scales type7537..how do i change from metric to imperial
SOURCE: setting is in metric instead of pounds
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Posted on Nov 21, 2008
SOURCE: I have a tanita tbf-612
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
fitnessbalan
  • 59 Answers
SOURCE: instruction manual soehnle scale
I have looked and maybe you have the model number wrong the scale you are talking about 63700 Calando Quattrotronic scale is a simple digital scale and does not provide bmi, and hydration.
here is a link to the manual, http://www.leifheitusa.com/manual/63700.pdfit is in several languages including english as the company is european and sells to many countries. If you look english is there it is a very simple manual as the scale is only desinged to weight in either lbs or kgs nothing more. Sorry. If you would like a bmi chart you can get that here http://www.healthdiscovery.net/links/calculators/body_massindex_chart.htm and figure out your bmi based on height and weight in the chart.
Posted on Apr 24, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
I just installed a new CR243 battery in my Soehnle bathroom scale, A red light came on inside, but nothing happens on the screen. Can you help?
Sometimes a CR2340 battery is still in it's package, but it may be very weak, even though it tests OK. Try another good battery.
Jun 15, 2017 | Soehnle Health & Beauty
Programming soehnle volga
If battery replacement did not help, the scale may have failed.
Sep 19, 2016 | Soehnle 63691 Volga WhiteGrey Body Balance...
I have a Scale Master 2 i want to get it to english standard from the metric that it seems to be stuck at, help
For Scale Master Pro XE Advanced Digital Plan Measure Model 6135 (with PC interface cable Part # 5006).
Switch the Imp/Met Switch to Met
While in Metric mode, MET will remain lit in the display
For Scale Master II v2.0
1)Turn until off via switch
2)Press and hold [SUB] key
3)Turn unti on via switch
4)Release [SUB] key
While in Metric mode, MET will remain lit in the scale box.
Repeat procedure to switch back to Imperial mode.
Sep 23, 2010 | Calculated Industries Scale Master II w/PC...
I replaced the 9 volt battery on my Soehnle scale and the display on the front reads 8888888 and stays that way, never going to 00. Please advise.
mcdevito75 here, You can try to disconnect the battery, then step on the scale then step off, Now re-install the battery and see how it works. If same contact scale manufacturer.
Jun 29, 2010 | Soehnle Linea Quattrotronic Digital...
My weighing scale is not working
try checking the battery and installing a new one
Jan 12, 2010 | Soehnle Linea Quattrotronic Digital...
New Aqualand promaster dive watch JP1010-01L. Temperature currently displayed in C. How do I change display to F.
Called Citizen Customer Service and was told that there is no way to change it. These watches come set with metric or imperial scales from the factory and cannot be changed.
IT SUCKS !!!!!
Apr 21, 2008 | Breitling Navitimer A2332212 G5 431A watch
Soehnle Linea Quattrotronic Digital Bathroom Scale Logo
153 people viewed this question
Top Soehnle Health & Beauty Experts
ray gallant
Tom Chichester
Michelle Balcom
Are you a Soehnle Health and Beauty Expert? Answer questions, earn points and help others
