Question about Rio SE510 (512 MB) MP3 Player
Recovery Mode When I turn on my Rio se510, it says upgrade and my computer is telling me its in recovery mode. Usually if I hit it once or twice or fiddled around with it, it worked afterwards. Now it won't
  • mowcius May 11, 2010
    Have you tried re-formatting it? or won't your PC let you do that?
5 Suggested Answers
SOURCE: rio forge
Sorry for reverting to the basics, but have you tried taking the batteries out of it? That should revert it to its basic configuration.
Posted on Aug 17, 2006
SOURCE: My Rio says upgrader when I turn it on
UPGRADER is a mode that purges the firmware from the Rio player prior to flashing the unit. Firmware is basically the operating system for the player, so if it is corrupted any number of things can occur. You can enter UPGRADER mode to update the firmware on your player by holding down the MENU button when you power the Rio ON. Flashing the player in this mode erases all content. Try the following to get the unit out of UPGRADER mode, if powering OFF the unit will not correct it. ALL PLAYERS - If you accidentally entered UPGRADER mode, turn the unit OFF and then back ON again. - Download the latest version of the firmware for your player and upgrade the unit. Visit http://www.digitalnetworksna.com/support/rio - It may be necessary to run the firmware update more than once. - This process may erase content from your player. - If the player is detected by the computer, it is recommended that you format the player, which WILL erase content from the player. - Macintosh user's try flashing the player on a PC. FLASH MEMORY PLAYERS - Remove the battery and replace it, this will reset the unit. The Rio Forge, Rio se510, Rio Cali [Black Rio Stick], and Rio Chiba [Black Rio Stick] can lock up causing the player to be unresponsive. If this occurs there are two things that need to be performed to resolve the issue. First you want to remove power from the player this includes the battery and a USB connection for 20 minutes to reset the player. There is a capacitor on the player that stores a charge that holds the player in the locked state. By waiting the duration the capacitor will discharge and the player should function as normal. Second you will want to upgrade the firmware to the latest version and format the player to prevent future occurrences. HARD DISK DRIVE PLAYERS - If you have a Carbon, Nitrus, Eigen, or Karma, use a paper clip to reset the unit. Your Rio will power off automatically when it has been reset. It may be necessary to connect the player to AC power and then reset the player if it will not turn on. If you are still unable to have the player exit UPGRADER Mode, then try it on another computer. UPGRADE FIRMWARE - Connect to the internet - Go to http://www.digitalnetworksna.com/support/rio/ - Click on the appropriate player - Click on the FIRMWARE tab [showing by default] - Click on the latest firmware file [example: RioForge_firmware_133.exe] - Click SAVE when prompted - From the SA
Posted on Feb 27, 2007
  • 883 Answers
SOURCE: player says "restarting" but never restarts
look for a small pinhole to reset the device..to bad RIO did not provide a way to "go back" in case of failed firmware
Posted on May 28, 2007
SOURCE: Rio Carbon Stuck in Upgrader Mode
Hi Allyson,
This is a problem which I have encountered alot with my Rio Carbon.
A solution which always works for me is to hold the player face down in my left hand and then slap the back of it with my right palm a little harder than I would if I was winding a baby.
Best wishes, I hope this works for you as it does for me.
Posted on Apr 07, 2008
  • 155 Answers
SOURCE: rio ce2100 upgrader
You probably have broken the hard drive,
Try replacing it with a CF card,
Everybody says that this does not work but it definitely does!
My Rio got dropped and I completely buggered the hard drive so after reading many forums saying that it didn't work I read one that said that someone had told them that sandisk ultra II ones worked (very vague!)
Because I had nothing to lose I went out and bought a 1GB sandisk Ultra II CF card. I then took apart my rio and replaced the hard drive with the CF card. Still not thinking it was going to work I plugged it into my computer and installed the latest firmware (from the rio website) and then HEY PRESTO!!!!!! it works.
I have yet to try an 8GB ultra II card but when I do i will keep you posted.
If you don't believe me then I don't blame you but If you send me a request then I can send you pictures and more details...
Rio will live on
Hope this helps
Mowcius
Posted on May 13, 2008
Recovery mode with out using the power button
An iPod Touch's "Recovery Mode" is for alleviating major operating system issues.
Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit.
The goal of this total system recovery is to revert the iPod to a stable, usable version.
Before you use Recovery Mode, exhaust other troubleshooting methods.
In some cases, Recovery Mode is triggered automatically after a failed system update or system restore.
When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process.
You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Turn on your computer and open iTunes.
If you are prompted to download any new iTunes updates, install the updates before proceeding.
Plug an iPod USB cable into your computer.
Do not plug the other end into your iPod Touch yet.
Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step.
Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch.
Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen.
At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode.
Click "OK."
Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen.
Click on the "Home" tab, and then click "Restore."
Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again.
The restoration process takes a few minutes.
Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
iOS: Unable to update or restore
http://support.apple.com/kb/HT1808
Jul 31, 2013 | Apple iPod touch
My rio keeps saying upgrader when try to turn it on how do i fix this?
try hitting power and menu at the same time see if that helps because its usually what buttons put the player into upgrader mode and see if doing so has the reverse effect
May 27, 2012 | Rio Cali Sport MP3 Player
Help please tell how to exit recovery mode
How to Fix an iPod Touch Stuck in Recovery Mode With a Free Program
An iPod Touch's "Recovery Mode" is for alleviating major operating system issues. Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit. The goal of this total system recovery is to revert the iPod to a stable, usable version. Before you use Recovery Mode, exhaust other troubleshooting methods. In some cases, Recovery Mode is triggered automatically after a failed system update or system restore. When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process. You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Things You'll Need
-Apple iTunes-USB cable
Instructions
1 Turn on your computer and open iTunes. If you are prompted to download any new iTunes updates, install the updates before proceeding.
2 Plug an iPod USB cable into your computer. Do not plug the other end into your iPod Touch yet.
3 Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step.
4 Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch.
5 Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen. At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode.
6 Click "OK."
7 Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen.
8 Click on the "Home" tab, and then click "Restore." Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again. The restoration process takes a few minutes. Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
Dec 24, 2011 | Apple iPhone Audio Players & Recorders
Apple ipod touch 8GB For got password
1. Hold down Sleep/Wake button and Home button together, until the iPod touch powers off. Once the iPod touch turns on again, let go of the Sleep/Wake button about 1 or 2 seconds later, still holding the Home button. Once plugged in to your computer, iTunes will recognize the device is in Recovery Mode. You can now restore which will set the iPod touch back to factory defaults, thus removing the passcode.
2. Open up iLiberty+ and other the Other Tools tab select Enter DFU Mode. Your iPod touch will be recognized as in Recovery Mode by iTunes once you plug it in, at which point you can restore through iTunes. This will wipe the passcode as you're setting the device back to factory defaults.
3. Open up ZiPhone and select Prepare for Upgrade. You're iPod touch needs to be plugged in to your computer before doing so, and once you select that option iTunes will recognize that your device is in recovery mode. You can now restore through iTunes which sets the device back to factory default thus removing the passcode.
Apr 01, 2011 | Apple iPod touch
Recovery Mode
I agree, use the Reload Firmware tool on recovery mode and then upgrade the firmware from the website. If you get "firmware failed!", then try it from a different computer.
May 08, 2008 | Creative Labs Zen Digital Media Player
Hard drive
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 10, 2008 | Creative Labs ZEN Vision:M Digital Media...
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
Feb 14, 2007 | Rio Forge Sport Digital Media Player
Rio Carbon powers off
Sep 25, 2006 | Rio Carbon MP3 Player
My rio used to say upgrator and now its not turning on at all.
I think when you hit the on/off power button (on top near outlet for headphones) AND hit the menu button (on side below volume dial) at same time...it puts the Rio CE2100 into "Upgrader" mode aka "Recovery" mode. From what I've found online, basically, the firmware to the device is deleted. Trying to reinstall firmware, or reflash the device is nearly impossible. The tiny hole near the earphones is for resetting the device--use a needle (about the only thing that will fit-ouch)...but that only lets you turn it on/off if u get stuck. The tiny hole on face near display is where audio recording mic WOULD be if Rio CE2100 had one. If ANYONE knows how to escape "Recovery mode" or "Upgrader" mode please share. This is a common final result for many owners of this otherwise great mp3 player. There is some notation in online help site that says ce2100 requires 500mA from USB and says u can go to Device manager, check ur USB Root Hub, check Power tab to see how much power is being supplied to the device. Mine said 100mA, and doesn't work...but I don't know how to resolve this. =) Maybe tomorrow...or just wait for sales post-christmas. =)
Sep 08, 2006 | Rio CE2100 MP3 Player
Rio SE510 (512 MB) MP3 Player Logo
22 people viewed this question
Top Rio Audio Players & Recorders Experts
isaac johny
isaac johny
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
