Question about Bissell Vacuums
Dont remember how to put vacuum belt on - Bissell Vacuums
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 06, 2010
I have a powerclean bissell vaccum and i just got a belt to replace, is pulley the little metal part on the side where belt goes because when i put the belt over the metal part and around rotating brush...
You did not put the belt on its proper place that's why it happen. Replace again the belt and put it not over the metal part. Put a mark where the belt belong so that you'll remember it when you gonna instal the belt. A mark like pen or masking tape will do.
Thanks for asking.
Jul 13, 2011 | Bissell Vacuums
Dyson DC14 Bar brush and belt replacement.
Try the op manual http://www.dyson.com/customercare/manuals/us/dc14_opmanual_usa.pdf
Aug 30, 2007 | Dyson DC14i Bagless Upright Cyclonic...
The Hoover steam vac dual v does not spin its brushes and I dont know how to dismantel it to view the belt .
There is no belt on the steam vac - it operates on air flow. Remove the brush and insert a flat screwdriver into the square hole. If it does not turn, the turbine has seized up and must be replaced. Remember that the brush will not turn unless the lower tank is in place, and the handle is tilted back.
Jan 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How do I get this darn belt back on my Kirby?
We've actually shot a very helpful video repair on how to change the belt on your Kirby. Also, at the end of the video it shows you how to put the head of the vacuum back on properly. This video also gives you instructions on how to do routine maintenance on the roller brush to prolong the life of the belt. If you fast forward the video to the end though, you'll get an easy to follow answer on how to put the head of your Kirby back on.
Here's the video:
I hope this video was helpful to you. If this helped you fix your Kirby, please be sure to rate the repair as helpful by clicking the thumbs up icon on the top right hand corner.
Thank you!
Chris J.
GoVacuum
Apr 05, 2010 | Kirby G4 Bagged Upright Vacuum
It turns on but the spinner underneath wont work now
Turn the vacuum so the bottom is facing up..
Take out the scews in the plate that surounds the brush and take it off..
The belt should be firmly on the brush and the motor..
If the belt has come off the motor - pull out the side of the brush that the belt connects to.. Put the belt back on the motor post and the brush.. It might be a tad tough going back in because the belt should have a little tension..
Once the belt is on and brush in place - put plate back on..
Hope this helps ;o)
Jul 15, 2009 | Bissell 3576 CleanView II Bagless Upright...
Need to replace belt
Please go to this link on my business web site for instructions on changing your belt: http://www.sewvac1.com/Hoover_U5162_900.pdf
May 07, 2009 | Hoover Fold Away U5162-900 Bagless Upright...
How to put on a kirby vacuum belt
The emblem on the front of the Kirby vacuum controls the installation of the belt. Rotate this emblem. ( I do not remember which direction it rotates). This relieves the tension on the belt. Replace the belt and rotate the emblem back to lock it in.
Please rate this solution
Jul 31, 2008 | Kirby Vacuums
Oreck vaccum
The belt must not be running true to the pulley. You may need a brush roll, but also check the motor to make sure it isn't moving inward after the belt is put on.
May 17, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Belt
First take off the cover on the left side of the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Feb 13, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
