Question about Whirlpool Duet GHW9150P Front Load Washer
Rena40 oh ok i got the washer up and unplugged. Now the bottom piece has three screws on it do i remove those?
  • 1 more comment
  • Rena40 May 13, 2008
    Thank you so much i will try that and i will let you know if i did it.
  • Anonymous May 28, 2008
    sour smell
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Yes...the lower panel should drop down, then off. If it sticks, just tap on either side and it should come free.
  • 639 Answers
Remove the bottom panel 3 screws on bottom front ,
then you will see a large white (usually) filter access port ,
unscrew it and some water will empty so have rags or pan ready.
remove debris and see that the pump impeller is turning freely.
see that the float ball is loose and floating.
Posted on Aug 30, 2008
Makes noise on spin cycle.doesn't spin
.most likely you have a broken motor coupling part number 285753A and it's around 20 dollars.unplug the washer.on the top console there are two phillips screws that have to be removed,on whirlpool washers they have them in the rear one on each side,remove them and flip the console up.with a screw driver pop the two metal clips,put the screw driver in the hole and on top of the clip and push back to the wall,the clip will pop out,next you'll see a wire connector to the left of the right clip,unplug that,this is the lid switch wires.open the lid,grab the frame and lift up and pull back,remove the frame of the washer,on the bottom you'll see the pump,with a screw driver remove the clips and slide the pump off the shaft.then remove the two screws and pop the two clips off the motor and pull out the motor.on the back of the motor you'll see the coupling.most likely the three arms will be broke off,the other side of the coupling will be on the transmission.remove that part and the rubber piece.next tap on the new coupling on the motor shaft the other part on the tranny shaft.slide the rubber piece on the tranny part of the coupling and then line up the motor coupling so it fits into the rubber and both pieces are interlocked in the rubber.before you do this check the rubber pieces on the corners of the motor,if any are missing pull it off the frame and slide it back on the motor or you'll never get it back together,slide the motor back on and put the washer back together.the coupling breaks from overloading the washer
Feb 14, 2011 | Kenmore Washing Machines
The agitator is frozen what could be the problem? i believe the trans is locked up.
it could be the tranny or a broken motor coupling.remove the two screws that hold the top console down.flip up the console and with a screw driver pop the two metal clips.there's a wire connector close to the right clip,unplug that,it's the lid switch wires.remove the frame,down the bottom remove the two clips and slide off the pump.do the same with the motor,when you slide the motor out check the coupling on the motor shaft,the other piece is on the tranny shaft,the two pieces interlock with a piece of rubber that both pieces slide into,when the motor turns it turns the tranny also.if the coupling is ok then it's the tranny,check for signs of oil leaking out of the tranny.it's not hard to change out.three screws and it slides out.then you poke a hole in the top of the tranny with a paper clip,remove a couple of clips and cluth assy. off the old tranny and install them on the new tranny,slide it back in and reinstall the three bolts.send the model number next time and i can give you the parts numbers and prices
Jan 23, 2011 | Kenmore 22932 Top Load Washer
Washer drains but is not spinning
most likely you have a broken motor coupling part number 285753A and it's around 20 dollars.unplug the washer.on the top console there are two phillips screws that have to be removed,on whirlpool washers they have them in the rear one on each side,remove them and flip the console up.with a screw driver pop the two metal clips,put the screw driver in the hole and on top of the clip and push back to the wall,the clip will pop out,next you'll see a wire connector to the left of the right clip,unplug that,this is the lid switch wires.open the lid,grab the frame and lift up and pull back,remove the frame of the washer,on the bottom you'll see the pump,with a screw driver remove the clips and slide the pump off the shaft.then remove the two screws and pop the two clips off the motor and pull out the motor.on the back of the motor you'll see the coupling.most likely the three arms will be broke off,the other side of the coupling will be on the transmission.remove that part and the rubber piece.next tap on the new coupling on the motor shaft the other part on the tranny shaft.slide the rubber piece on the tranny part of the coupling and then line up the motor coupling so it fits into the rubber and both pieces are interlocked in the rubber.before you do this check the rubber pieces on the corners of the motor,if any are missing pull it off the frame and slide it back on the motor or you'll never get it back together,slide the motor back on and put the washer back together.the coupling breaks from overloading the washer.happy new year
Jan 02, 2011 | Whirlpool LSR5132PQ Top Load Washer
Have a foriegn object in the pump and i need to get thefront bottom panel off so i can acess it
Disconnect power and remove the three screws attaching the bottom flange of the lower front access panel to the cabinet. Once the screws are removed, pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Remove the pump filter by turning the knob counterclockwise and pulling the filter out. Make sure to catch residual water from the filter housing by placing a shallow pan or a piece under the filter housing to avoid flooding your floor.
Sep 09, 2010 | Kenmore 45981 Washer
How do I remove the bottom front panel on the washing machine?
First, unplug the washer for safety. Then remove the three 7 millimeter or t15 torque screws from the front lowest part of your washer - which will allow you to remove the lower front panel. It will be easier if you prop the front of your washer up on a couple pieces of wood or bricks first, so you can get to those screws more easily
Jan 31, 2010 | Kenmore HE3T Washer
My washer went on control lock and now it wont turn on i tried to unplug it but nothing works
Would plug something else into outlet to make sure your power supply is ok. If you remove bottom panel in front(three screws) or top panel(three screws in back and slide panel back slightly to raise off) there should be a tech sheet with some suggestions. If it is less than a year old call for warranty service. Keep kids away with panels off. If unit is completely dead a guess would be main control board on top, but that is just a guess.......
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Where is the filter on a whirlpool duet washer?
Unplug the washer. Remove the bottom front panel, usually three screws. You will see a round plastic piece that screws into the motor pump assembly, in the front center of the washer. Put a couple of towels down, unscrew this part, and remove it. This is the filter-coin catcher on the duet. Clean it out every 3 months or so. This is mainly for large items, so the easiest way to keep it clean is to just make sure there is nothing in your pockets. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 90 series mod.# 110.28912791
OK The Kenmore 90 series mod.# 110.28912791 is not hard to work on. The problem on the washer was no agitation or spin.First I took the agitater out of the tub,and put them aside. Then I tilted the washer to get to the bottom of the washer. Inbetween the motor and I gueuss pump there are three pieces that need to be replaced called (motor coupler). I disconnected ac cord from wall outlet, the cold and hot water hoses. I disconnected the wires at the motor one piece and one two wire connection pluss move a small canister with two wires out of the way. Removed three bolts bottom of pump pulled pump and motor out, you have to turn back and forth a little and the whole assembly comes out. there are two screws that hold two clips at side of motor and motor come off easy. You will notice there is a black rubber disc with a plastic white three prong piece on each side. (Remove those pieces install same way ( you need to use something to hit the center of the plastic till it sets in, install black rubber piece six wholes three prongs on one side. Install second white pronged piece on the pump side and also hit center to set. Place pump over motor looking to (make sure) the top three prongs go inside three holes left in the black rubber piece. Once you line and they go inside line the motor to where the for rubber legs sat before put clips back on install the two screws, install shaft back in moving the motor side to side install the three bolts, hook wires plugs under the motor put canister with two wires back hook the two hoses back next to motor, stand washer back up, install agitater back, hook hot and cold hoses back plug back in and test. parts at sears (one hours time start to finish taking your time) keep track of all parts. Make diagram if you need to believe me it was easy and washer works great now. By the way when I took the parts off they did not look broken but were bad because now I have a working washing mashine. ( Good Luck, Wyatt Earp )
Feb 02, 2009 | Kenmore 23822 Top Load Washer
Whirlpool washer
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
Jan 20, 2009 | Whirlpool Washing Machines
Won't spin
Remove the water pump by removing the two retaining clips. You do not have to remove the drain hoses. Just push the pump aside with the hoses still attached. Disconnect the wiring harness from the drive motor (good idea to unplug the washer before you attempt this). Remove the two stay screws on the retaining clips for the motor. Once the screws are removed, take a flat blade screwdriver and gently pop the two clips from the drive motor. Remove the bottom clip first, then place one hand under the motor before releasing the top clip. Be careful, the motor has some weight to it. Directly behind the motor is the motor coupling. There will be one plastic three-prong piece attached to the motor and one piece attached to the transmission. A black rubber bushing connects the two halves together. Look for rips or tears in the rubber bushing and/or broken pieces from the coupler. I hope this helps you.
Sep 11, 2007 | Kenmore 22932 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
