Question about Rode NTG-2 Professional Microphone
When I record with my ntg-2 mic it sounds really good through the head set I am listening with, but when I play the recorded sound back it is really really low in sound and there are glitches throughout the entire recording. how can I get the mic to record the great sound that I am hearing in my earbuds?
3 Suggested Answers
PoiSonPeZ
SOURCE: the mic does not record stereo
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Posted on Oct 25, 2009
  • 417 Answers
SOURCE: I plug my rode ntg-2 into the computer and record
This mic needs phantom power to operate. Best bet, go and buy a USB mic pre, such as a M-Audio product.
This mic, I believe also runs on a battery, when phantom power is not available...so check the battery.
Or, simply, your record levels are set too low.
Posted on May 27, 2010
Mic sound muffled static
Buy a better mic! This question reminds me of the musicians who invest in a nice JBL public address system but then use Radio Shack microphones. A good quality mic, not GREAT but just good will cost you a minimum of $100. Quit playing with toys and invest in real recording gear. Computers and hard drive recorders can easily record CD quality audio, and-so why would you use a $70 mic?
Sep 10, 2013 | Samson Samtr Meteor Mic Usb Studio...
Tip
Studio Recording at Home; Part Deux
This tip, continuing the series of Home Studio Recording, focuses on the hardest part of accomplishing this feat: Drums.
A big sound killer on 'budget' recordings is poorly recorded drums. There is a remedy, though. If you have one set of drum mics, buy another (or borrow. This will come into play later, though).
If you have clips that hold them on the drums, great. With the two sets, you'll only use half of the clips. For the rest of the mics, you'll want stands. You'll need one stand for each drum, plus six.
The dual mics serve this purpose: To capture the sound of the whole drum. One mic for the batter head (the side you hit), and one for the resonator (the side you don't).
For the batter head, you'll use the mic clips, and attach the mics as you normally would during playing. For the resonator head, use the stands to position the mic directly across the drum, making a straight line from the top of the drum to the bottom. This will help eliminate any voicing differences, which can be a real headache.
For the bass drum, you'll need 2 stands. Position the batter head mic close to the edge of the head on whatever side is easiest to access, but is also comfortable for your playing style.
Aim the mic so that it is pointed at a midway point between the center of the head and the edge. You can experiment with different spots, but be sure to NEVER let the mic be directly in front of the head.
For the bass resonator head (the front one that everybody sees), position the mic so that it is a mirror image of the batter mic. Once again, this gets rid of voicing problems.
You have just miked your drum kit, but what about cymbals? That's where the other 4 mics and stands come into play. Those 4 will take care of:
Hi-hats
Ride
Overheads
For the hi-hats, you'll want to position the mic about 3-5 inches from the top, and 2-4 inches from the side. It's best to come in from the outside of the kit, so that you'll pick up a bit of ambiance (the rest of the kit, as well as some natural reverb). Point the mic at a point close to midway between the bell and edge of the hats. Too close to the edge, and you'll get a sound similar to banging trash can lids together. Too close to the bell, and there's too much high-mid noise that CANNOT be reduced with an EQ.
For the ride, follow the same instructions for the hi-hats, but add about 2 inches to the distances. Aim the mic a little closer to the center as well, so that the mic will pick up any bell hits. A good spot is 1/4 the distance between the bell and edge.
Now for overheads. These are the mics that not only record the cymbals, but pick up the most ambiance.
NOTICE: I haven't already mentioned it, but you do NOT want to record with the drum kit up against a wall, nor do you want it in the center of the room. For best results, use the midway rule (as with placing mics on drums and cymbals, place the kit midway between the center of the room and the edge, preferably headed towards a corner). This will reduce unwanted echoes in the room due to sound reflection.
You will want to place the overheads about 1.5 feet above the highest cymbal. Space them out so that the entire kit is between them, but be sure to keep them evenly spaced. You'll want to use the snare as a midway marker for the placement of overhead mics, since it is your loudest drum, and more likely to be picked up in the overheads than any other drum. This will also keep the snare panned center (you'll be panning the drums out to the left and right later on the mixer, but the snare and bass stay center).
These are some guidelines for setting up mics for recording drums at home. I hope that helps, and stay tuned for Part Trés of Home Studio Recording.
on Mar 13, 2011 | Music
I have a TASCAM PortaStudio 424 mkiii 4-track tape recorder-mixer. When I record a new track and listen back to it, everything sounds great. After a couple times of listening to it, and overdubbing other...
It is probably a hard to find record electronics problem and possible that the record bias is staying on partially. This will erase partially the audio and apply the clicks. You are going to need a good Technician for this. Try this guy- I have confidence in him.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
Dec 17, 2010 | Tascam Audio Players & Recorders
I plug my rode ntg-2 into the computer and record using audacity and the recording is extremely low in volume.
May 20, 2010 | Rode NTG-2 Professional Microphone
Rode NTG 2
You'll want to connect it to any mic input using either an XLR cable, or an adaptor cable or transformer appropriate for your input, e.g., 1/4" or 3.5mm.
Aug 03, 2009 | Rode NTG-2 Professional Microphone
No Sound When Recording
Video camera has built in microphone which is on at all time until you plug in different type of mic then camera is switched to new mic. Audio problem may be on audio head or circuit problem. You can test the system by playing pre-recorded tape to see if it play with the sound and go from there. If it play but does not record sound, you have audio recording problem. If it does not play, I would clean the video head and audio head area good. -James For further assistance, request help at www.camerarepairjapan.com
Apr 11, 2009 | Panasonic Video Cameras
How do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
Mar 17, 2009 | Canon XL2 Mini DV Digital Camcorder
When boss dictates a letter I can barely hear any sound!
The tape might be getting old, replace it and see what happens.  If it is still acting up, It might be he is not recording properly or the recorder is bad.  Try talking directly into the mic and see if it is better.  If it is, he needs to talk louder or needs to hold it close.
Mar 04, 2009 | Dictaphone 3225 Handheld Cassette Voice...
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
No sound
playback on the camera? good news is that there really may be nothing wrong with thecamera
this model doesn't have a speaker. but it has a mic so it can record sounds
when you transfer the videos to the computer - it is supposed to play with a sound
Feb 07, 2008 | Kodak EasyShare C513 Digital Camera
Rode NTG-2 Professional Microphone Logo
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Jay Plesset
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
